My system-
Onkyo SR444
Paradigm CT 100
I am quite satisfied with the quality of the sound that I get currently. But the bass from 8inch Cinema sub is quite soft edged. I had a Logitech Z5500 10 inch subwoofer before. That was quite hard edged tight sounding one.
Please suggest me if there is anything that I am missing. Suggest me if there is any setting with the av receiver that can result in tighter bass. More of beat bass and less of harmonic humming bass. The sub is in corner of the room. The setting in avr is -3 sub and sub itself is set at 120hz. Power level at 30%. Crossover in avr is at 80hz.
Thanks in advance!
Onkyo SR444
Paradigm CT 100
Thanks in advance!
