prateekatasniya
Isolate the sub from floor.
Use gym rubber flooring.. get a single rubber tile. Will cost around 300 rupees
IMO, though a UMIK-1 & REW are viable solutions, the landing cost of the Mic is anywhere between 10 ~ 12K, and then it would demand the user to have hands on with REW & then figure out the ideal response thru multiple measurements.. For a lil more money that he would spend on Mic, he can get an other sub (Dual identical sub) (or) more possibilities of getting an other 10inch affordable sub, which could help the user.. This is purely from a cost perspective..
The best the user can do in the present situation is, to re position the sub as many times as possible in the room and settle where he thinks / feels it is good..
Or get some tennis balls to isolateIsolate the sub from floor.
How about drainage rubber mats?Isolate the sub from floor.
My subwoofer was on carpet earlier, keeping it on this gym rubber tile reduced boominess to an extent.. but the best option would be bass trap.H
like https://www.amazon.in/Kuber-Industries-PVC-Doormat-Black/dp/B075HVQQQF
or simple noodle Mats used in Car floors or a car rubber mat?
I don't think these will work that good.. IMOH
Regarding the height, anytime you change it for a speaker it changes the way sound interacts with room boundaries. That is why a small change in speaker position in any direction, including height, is likely going to impact its performance in the room.
Thanks for the help. The bass is boomy. It is humming or I think it's called mid bass, and it should decrease. Only the thump should be felt.
By soft bass I meant the beats are not felt as they should be. The Logitech 10 inch sub did not have a port at the rear. Paradigm has two rear ports.
What does isolation do for a sub on tennis ball.. I feel, a few inches in height wouldn't change anything for bass..
Isolating the sub away from walls/surfaces is the same as moving the sub inwards to the room, away from boundaries..
its not the height. but vibration control which happens with tennis balls. If it was for height, anything would have done that, instead of the tennis balls. They are made of rubber if I am not wrong. works like an real hifi isolation platform.
You can try changing the orientation to 45 degrees. When I had my Logitech z2300 it worked in my room only good at 45 degree. So depending upon room you it may work for you as well.Thanks for all the inputs everyone. I will be renovating my house soon and treating it acoustically. Will be making a dedicated home theater room.
The first change I did was the distance and crossover. It has changed the sound a bit. I will try dampening now.
