Thad E Ginathom
I would rather use a higher sampling rate, than higher resolution.
Go for 48, rather than 44.1. It's the one no-one seems to argue about being technically superior. On the other hand, I have ripped at 96, just in case I ever invite any bats to a listening party.
On the resolution, though, I think you could be wrong. IIRC from reading my old Cool Edit Pro manual (Oh, how I miss that software!) was to work in 32-bit because that way effects etc are more accurate, because the calculations are floating point.
If you have a sound card (now is the time to regret buying a one-way-street DAC
Making good rips, with minimised crackle and cracks, is a real labour of love, and takes some skill too. I'm a junior in the field.
My first hint: back up the files from your original rip. Keep that "raw data" at least until you are happy with your edited files. And save your work often
