HX 750 vs HX 850 vs ET5 vs ST50 vs ES6200
This should help.
ES8000
After calibration we measured black level to 0.04 cd/m2, which is one notch up from last years D8000 but in real life a very tiny difference. It might occur due to very small differences in distribution of the edge LED-backlighting on the panel. It means that Samsung holds one to their leadership position together with Sharp amongst the edge LED based TVs, and it also means that ES8000 is actually outperforming some plasma TVs in an area where plasma TVs traditionally have had an advantage.
Our Samsung ES8000 sample had no critical clouding or bleeding issues. Brightness is not distributed 100 % evenly on the panel but this is true for every single edge LED based TV out there today. Compared to for example Panasonic DT50 and LG LM7600, our ES8000 sample was far better and we never noticed light leakages during movie watching, gaming or other sequences.
Viewing angles have not changed compared to last years models. Viewing angles are still fairly wide and you can enjoy the TV from most angles but you will notice that some colors loose intensity from extreme angles.
Samsungs 3D implementation is great and applicable but I would personally still love to see Samsung switch to a passive 3D solution on their LED models. It is true that active 3D theoretically has a higher resolution and therefore better 3D detailing but active 3DTV also struggle with crosstalk, flicker and expensive 3D glasses. 3D picture quality on ES8000 is good enough for mixed use, sure, but only slightly improved compared to last years line-up.
Source: Samsung ES8000 (LED) review - FlatpanelsHD
HX850
After calibration we measured black depth to 0.06 cd/m2, which is fairly good compared to the typical edge LED based TV, and only slightly higher than Samsungs ES8000. However, Sony has not improved black level reproduction dramatically in the past few years.
Clouding / bleeding is always a difficult subject because we know from experience that it can vary a lot from one TV to another. Our Sony HX850 had very modest clouding and is one of the best edge LED based TVs we have seen to date but our experience tells us that the complete story is impossible to tell with only one test sample. Only when users start received their TVs, we can truly tell if the manufacturers has addressed the issue or not. But as said; our HX850 sample had no serious clouding issues and we did not notice any problems during everyday use.
To put it in context, HX850 is on par with most other LCD-TVs in this price range. 3D picture quality is fair but not great. Our main reservation with Sonys 3D implementation continues to be that the 3D effect vanishes if you tilt your head only slightly to the side.
The viewing angles are not particularly wide. We were unable to confirm but it looks like a Sharp panel inside the HX850. Sharps panels have some color washout issues and colors often look pastel from an angle. The same thing occurs on HX850 from 30-40 degrees angles or more.
Source : Sony HX850 (HX853) review - FlatpanelsHD
Then go for HX750 at 99K
regards
+1 to Ragav's suggestion. Get the HX750. Best option after HX850.
So I visited the Sony brand room on J M Road today evening. I was there for nearly 25 minutes. No one paid any attention to me. :mad:
Not that I wanted undue indulgence but I was not alone. There were other customers and the salesmen paid no attention to them as well.
Sent from my GT-I9100G using Tapatalk 2
Oh my ! I've had nothing but good experience at Sony Center JM Road. Maybe you should visit Croma then. Aundh Croma has the HX750 and HX850 in a special Sony Bravia section.
Croma Kothrud has both as well. Or you could even check out Sony Center Aundh.
Thanks. I will visit them. I do not have good experience with Croma - they are usually out of stock with most items.
Well then I can suggest Sony Center Aundh, and also Reliance Digital outlet in Aundh. But for the best demo Sony Center Aundh would be THE place. Actually the JM road outlet is better but since you had a not so pleasant experience there you should check out the Aundh outlet. Also Sony Center in Ideal Colony, Kothrud is good too.
Maybe the JM Road experience was once in a while aberation. TV is for my in-laws. I am thinking whether an Ex650 is also sufficient for them. They do not need 3D. But they are users of Sony WEGA Trinitron 29" and hence PQ is high on agenda (especially for my F-I-L).
I feel the same thing..in sony center they don't pay attention even you're standing before a large tv..:rolleyes:..where in a showroom with all brands if you are standing before a large tv guys will come rushing to pay u attention..:ohyeah:
@just4kix
I think the EX650 should suffice, it has very good PQ. :) Or if 3D is needed then HX750 will do as well, it's also got very good 2D performance with the right settings. I really doubt your FIL will be even slightly disappointed with the PQ ;)
@just4kix
I was checking 40EX650 in showroom yesterday. It was quite nice - definitely not in the league of HX850 but things must be taken in proper perspective. I work in Hinjewadi and will drive down to Aundh showroom today on my way home (Ganesh khind Road).
Do make sure they get an HD connection. Most make the mistake of buying expensive TV's but use SD connections. The PQ of the Sony trinitron is quite good for SD so even the best LCD/LED will struggle to match it for a SD connection.
ES8000 was one of the LCD tv contenders for Value Electronics 2012 Flat Panel Shoot-out, while none of the sony LCD's where even considered for an entry.
The Contenders:
Panasonic TC-P65VT50 65-inch plasma HDTV
Samsung PN64E8000 64-inch plasma HDTV
LG 60PM9700 60-inch plasma HDTV
Samsung UN60ES8000 60-inch LED-lit LCD HDTV (side lit)
ELITE PRO-60X5FD 60-inch LED/LCD HDTV (full array LED backlit)
Panasonic TC-L47WT50 47-inch LED-lit LCD HDTV
