Arajsriv93
Hey everyone!
Recently i lost my altec lansing vs3251 5.1 speakers. It just died on me. The power light comes up but there is no sound output and i dont even know if it can be repaired.
So i am confused what to buy next. 2.1 should be enough as i definitely need a sub. However there are lot of options out there ie Z906 ( dont want to buy this as its not reliable as per what i have seen online ) and then there is the edifier edifier s350db . Along with this you have the yamaha and the sony HTIB which cost under 30k .
And then there are bookshelf speakers. So what i thought was to buy the Edifier R1850DB which has a sub out and then buy an active sub later. Not sure what to do guys. Please suggest. Max budget 30k + - 10% . Room size 12 feet * 9 feet with a ceiling height of 10 feet . Going to use it with my desktop mostly and phone.
Thanks a ton for your help in advanced.
