Knightrider
Thank You. There are many versions of these brand cables, which ones would be better i.e version/ model ?Congratulations. You can go with belden or mogami speaker cables. Will be better than amazon basics.
Regards.
I am not sure about it. There can be sound signature differences. Let others comment here.Thank You. There are many versions of these brand cables, which ones would be better i.e version/ model ?
Regards.
Along with Amazon basics speaker wire, I also have 1.5, 2.5 and 4 sqmm copper cables of havells brand lying around. I think I'll try electrical cables (as discussed in few threads) and Amazon basics wires, and see if they perform different, as I already have these.I am not sure about it. There can be sound signature differences. Let others comment here.
If you have a budget, then go with branded cables, but it will cost a little more. If you want high-quality handmade cables, then contact Murthy Sir; he will make your speaker cables as you want. I am using Murthy's interconnect; they are excellent cables. If you like, I can share his contact number.Along with Amazon basics speaker wire, I also have 1.5, 2.5 and 4 sqmm copper cables of havells brand lying around. I think I'll try electrical cables (as discussed in few threads) and Amazon basics wires, and see if they perform different, as I already have these.
2nd query - do I need to burn in speakers?
If yes, then for how many hours approx?
Thanks for input. Please suggest a few branded cables with model no. Will contact you once i get a hang of how the speakers perform, and If I decide to go for Mr Murthy's cable.If you have a budget, then go with branded cables, but it will cost a little more. If you want high-quality handmade cables, then contact Murthy Sir; he will make your speaker cables as you want. I am using Murthy's interconnect; they are excellent cables. If you like, I can share his contact number.
Yes, speakers and cables need to be burnt in. It's according to the brand, mostly 100 hours of listening, but some take more than 150 hours too.
happy listening
cheers
I am using Mogami 3104. But it's not very cheap. 3103 is also a good cable. But I am not very familiar with other branded cables. If you are handy, you can buy cables per metre and try the DIY route.Thanks for input. Please suggest a few branded cables with model no. Will contact you once i get a hang of how the speakers perform, and If I decide to go for Mr Murthy's cable.
Regards.
yes, you can try. I was using polycab 2.5 sqmm cables before switching to belden and there was a noticeable change in sound. The mids became little more sweet.Along with Amazon basics speaker wire, I also have 1.5, 2.5 and 4 sqmm copper cables of havells brand lying around. I think I'll try electrical cables (as discussed in few threads) and Amazon basics wires, and see if they perform different, as I already have these.
1 - Placed on two 27" height hardwood stool type tables. 6feet apart, 1 feet from wall, tried feet from wall too. Near field and listening Spot at 10 Feet also.1 - Where are these placed? Are they being used for near field?
2 - What is your amplification?
3 - Do you use a sub?
Thanks!
Can you post the picture of the Amazon Basics RCA cable. How long is it? is it longer than 1m? IF the cables have high capacitance it will tame the high frequencies. Most likely it is the source material being used for playback. Can you put one music file on google drive that you have a problem with? If you install audacity and load the music file you can see the frequency spectrum and see if the frequency range is throughout the audio range.1 - Placed on two 27" height hardwood stool type tables. 6feet apart, 1 feet from wall, tried feet from wall too. Near field and listening Spot at 10 Feet also.
2 - Aiyima A07. Chain - Windows 10 PC (foobar + Flacs and Wav) == USB == Ifi Zen Air Dac ==Amazon Basics RCA cables == Aiyima A07 === Amazon Basics 14awg Cable (new cable).
3 - No sub. QX2 MK II already has too much low bass, it overshadows all other frequeincies except male and female vocals.
Have attached flac file speck spectrum and amazon basics cable photos.Can you post the picture of the Amazon Basics RCA cable. How long is it? is it longer than 1m? IF the cables have high capacitance it will tame the high frequencies. Most likely it is the source material being used for playback. Can you put one music file on google drive that you have a problem with? If you install audacity and load the music file you can see the frequency spectrum and see if the frequency range is throughout the audio range.
BTW Human whispers typically fall within a frequency range of approximately 200 Hz to 4,000 Hz, with the most important energy concentrated between 2,000 and 5,000 Hz for intelligibility.
You can also use spek instead of audacity to analyze the audio. Download it from https://www.spek.cc/p/download
YOu should see a spectrum like this
I asked the photo of the RCA cable, not the speaker cable.Have attached flac file speck spectrum and amazon basics cable photos.
Both left and right speaker cables are of equal length - 9 feet 10 inches/ 118 inches/ 2.99 meter .Looks like copper, connected bare wires at both amp and speaker terminals.
Have played 100s of songs in 12 hrs play time, and few songs on youtube too. I solely listen hindi songs, and almost of all collection is ripped in flac and wav form. Most riles are of mediocre quality but some are good quality recordings and rips. Sound signature remains same throughout.
My apologies, i overlooked the details.I asked the photo of the RCA cable, not the speaker cable.
The spectrum shows you have very low volume for anything above 6 kHz. Let me check my sample of Choti Si Asha
This cable is fine. I too have this cable and have measured it's capacitance using a LCR meter.My apologies, i overlooked the details.
https://www.amazon.in/AmazonBasics-2-Male-RCA-Audio-Cable/dp/B01D5H8P0G - here is the link for RCA cable, its 4 feet long.
Here is my spectrogram. This is for the Tamil version which I ripped it from a CD of Roja purchased in Chennai from a roadside CD shop. I think it is similar to yours.
Thanks for teaching me to how to read spek graphs, always saw this but never knew how to decipher it.Let us ask other members to download spek and post the spectrogram of Choti Si Asha. Most likely my copy is bad too.
Try to obtain a good hi-res download of some Music and play it.
This is how a very good recording looks like. This is "A Night in Tunisia" by Art Blakey & The Jazz Messengers. The red colour is visible throughout the frequency spectrum.
You are using foobar. It has graphic equalizer to the best of my knowledge. You can use the sliders on the left to lower the low frequency and sliders on the right to enhance higher frequency. Apart from that you can use a preamp with bass and treble controls.Thanks for teaching me to how to read spek graphs, always saw this but never knew how to decipher it.
Will to find and wonload hi resolution file, any pointers as to where i can find one.
What else can i do to tame/prevent lower frequencies overshadowing other frequencies ?
Also, regarding placement of speakers - Which material is preferred for speaker stands i.e metal/solid wood/ plywood? Do i have to buy professionally made one or i can DIY with the help of carpenter/ metal worker? Or can use Sofline Pro stands on my 72x32 inch deep desktop table without any degradation of SQ?
Regards.
At the bottom of the spectogram if you see yellow or white strip it indicates strong bass frequencies.Thanks for teaching me to how to read spek graphs, always saw this but never knew how to decipher it.
