Hi again guys,
I'm having my onkyo 3500 5.1 ht set up today, and i've been online since more than 2 hours, and there is just so much info on the net, and its not consistent..
I wanted to know what the best position would be to place my speakers in my room.
Some posts swear by wall mounts, some say keep it away from walls,
some say place center speaker close to your ears (infront of tv) some say place it above or below tv (mount)
Some say sub-woofer should be in the corner of the room for powerful bass, some say it should not !
Since i dont want to spend more on stands, i will have them wall mounted only, and can't figure out the best position to do so.
- Should i place the surround L and R on the wall behind me,or on the walls on my either side?
- Should i have the center speaker wall mounted slightly above the tv (tv is not mounted,is on a stand) or should it just be on the same table as the tv, infront of it?
- sub-woofer i guess i can move around even later,
- How far should the front left and right speakers be on the wall behind the tv?
- Should the front speakers and surround speakers (on opposite walls) be placed symmetrically) ex-front left and surround left opposite each other?
Room dimensions ~14 feet X 14 feet .
