IFFALCON TVs owners thread
It is banned on Mac and iOS App for some reason. Works when you use web client. Apparently, someone spammed the group with pornographic content and someone else might have reported it. Not sure if it is against the rules of the forum, but here is the link for the telegram group:
Does the Netflix app play 4K context on tv coz wt ever the show I see it’s tagged as HD and in the starting ppl mentioned when a HDR 10 video is playing in Netflix it identifies and displayed which never happened in my TV
Only in Youtube it happens ... is there any workaround, lemme know please
hi guys am planning to buy 55k2a during tomorrow's sale, do you guys still recommend it or some other model?
thanks
Does this TV support DVB-T2 reception and has anyone tried in Metros for DD reception? What antenna is used?
Hey Everyone,
I am an owner of the IFFalcon 55" 4K like most of you and I wanted to seek help from the group regarding 5.1 capabilities of the TV. So the situation is this:
I am planning to invest in a home theatre setup (Onkyo AVR + Wharfedale 5.1 speaker package) and plan to use it mainly with Netflix and Amazon Prime. Can you all help me in confirming whether the TV will be able to pass 5.1 Dolby Digital or Dolby Digital Plus audio to the receiver via the HDMI ARC port? I have gone through this entire thread and some people confirmed that 5.1 output from the TV works fine, some mentioned that it is only able to send stereo audio.
Additionally, the IFFalcon website mentions that this TV also comes with a dts encoder in addition to the Dolby audio encoder. Has anyone tried to stream any dts content through the TV to their 5.1 setup?
Inputs from you guys would be really helpful. Thanks in advance.
Hey Everyone,
just a suggestion buy a dedicated Android box or may be Firestick 4k, you will be amazed by improvement in viewing experience as these low end Tv lags a lot and performance does not match what they claim.
Agreed! Buying a Mi Box S would be my last resort to ensure Dolby Digital passthrough to the home theatre.
Hi everyone, I recenctly purchase iFFalcon 55K2A because there was a really awesome deal going on the night before Gudi Padwa, so I got it for 33k.
My initial expressions were:
1. Although the panel is good for its budget, the interface seems really laggy or bugged. I was experiencing stuttering very frequently, on all the apps, maybe because I was streaming of off 5GHz WiFi, will use 100Mbps Ethernet and test to see.
2. I received my unit with very initial version of firmware, 31x dont remember exact but it seems really old. When I tried Network Update, it displayed no need to update (my internet connection is 45Mbps Up & 45Mbps down), tried local uprgade using USB 3.0 pendrive but I wasn't able to see Update.pkg even though it was in root directory.
3. Tried manual upgrading using holding power on button using each time with all 364, 387, 459, 511 version of firmware but it still booted into the OS.
Please advice which firmware version should I upgrade to and how. Or is there some way to schedule a appointment with technician to do the same.
Will try factory reset and see if the problem of laggy interface gets fixed.
Please tell me if you know solution to my above mentioned problems, sorry if this post is repetitive or the solution to the problem is already posted above (went through first 13 pages and then couldn't continue to scroll through due to time restrictions)
Also drop some apps which I could use to consume 4K HDR Content, plan on using this TV without DTH connection so need more options ( have installed thop TV )
After repeated followup on audio related problems since last week of Jan, IFFALCON sent their technician on Apr 14 to upgrade the firmware to 511. It created new problems now - the TV lost it's 'Instant Power ON' feature (it works for a while, but if TV is off for more than a few mins, TV does a cold boot when tried to come out from standby / on) and yellowish tint in video (doesnt go with any settings on tint/colour adjustments). Did anyone face similar issues? BTW, I finally opted to use an external S/PDIF Optical to Analog adapter board to get rid of that audio problem. Optical port works better than the headphone port or native speaker sound.
Hey Everyone,
First of all, I can confirm that the person who said this TV can only output in stereo via HDMI ARC is absolutely wrong. Because of him I unnecessarily spent Rs 350 on an optical cable instead of using the HDMI cable that came with the soundbar. I am using Sony HT-RT3 5.1 soundbar connected via HDMI ARC. This soundbar supports both Dolby Digital and Dolby Digital+ formats and both work great. I am able to get proper 5.1 output from Netflix, Amazon Prime as well as the built-in media player. For 3rd party players like Kodi and Nova Player you need to enable HDMI passthrough in their settings. Kodi is particularly useful because I can play mkv files with DTS and DTS HD-MA 5.1 as it transcodes the audio to Dolby Digital 5.1 in real-time.
Another benefit of connecting via HDMI ARC is that I can control the speaker with TV remote. When TV is turned on, it turns on speaker as well and the same applies while turning TV off as well. Soundbar volume can be controlled with TV remote as well. With optical out I had to use both TV and soundbar remotes. One benefit of connecting via optical out is that the TV can decode DTS audio natively and then send to soundbar even though the soundbar does not support DTS. But that can be easily overcome with Kodi.
Please mail me [email protected] how to get led replacement because I purchased in ,30 Jan 2019 after 15 day panel become faulty but I got no response from iffalcon to get replacement
Well, I noticed the defects related to audio within 24 hours of installation, so raised the complaints immediately. IFFALCON kept complaint pending and when there was no response, I asked Flipkart to take back the defective unit. However, this was all within the return window. The seller sent a person to try upgrade the OS. when it did not make any difference, after a reminder, seller conveyed to me via Flipkart that they will replace the TV. Replacement was done, but the new unit too had the exact same problems.
Thanks a ton @naveenjn for the detailed response on this! Super helpful. :)
Quick follow up question - Did you have to turn on any specific ARC related settings in the Iffalcon TV settings to ensure 5.1 output?
There is no specific setting for 5.1 output. But to make HDMI ARC work, you need to enable a setting called T-Link in settings.
I was trying to update my 55K2A manually. I was going through the steps mentioned; pressing both the power buttons. IT came to the small screen do not turn off while updating. But i waited for 2-3 hours. it didn't change from that screen. So i turned off the power. Later when i turned on it showed erasing with circles graphics. After that it came up with the blue screen with iFFALCON logo, but didn't boot up. I waited for many that it will go away. But its the same till now. Can someone help on this please?
Hello! May i please know if you somehow resolved this issue?
any links for updating 40F2A models? I have been searching on web but no success...all i am finding are different versions of K2A? Please help or suggest me a method or a portal where i can find it..
Dear all,
Here is a brief review. Not really sure how photos will help in the review. But if you want, can upload them later.
Before I do the review -few caveats which I have mentioned above as well. I am not a pixel peeper. I just want a large screen which I can enjoy. 90% of the viewing on this tv is done by family and hence no one cares about HD or 4K although they do appreciate the clarity that HD channels give.
My overall experience has been that I am pretty happy with the purchase. This TV as can be seen on you tube reviews is not as thin as the MI but not as bulky as my Plasma either and hence I guess a sweet spot where you dont have to worry about accidentally knocking it off its perch.
1) Smartness - while my Panasonic TV is a smart one - it is 6 years old and it was not a pleasure to operate its smartness. This TV in turn is a certified Google/Android TV. Basically its a giant mobile phone minus the SIM and few sensors and cameras. I believe one can do pretty much everything with the Android OS that one normally does on the phone. I haven't tried much - kids downloaded couple of games and I downloaded few AV apps. The speed is pretty good - not much lag when you operate the remote scrolling between apps. Hence this one is a Pro for the TV - breezy operativeness of the smart features
2) I am a computer to Kodi to receiver to TV/Projector guy. Watch whatever I can legally and download from pirate sites for the rest. Because of the issue with my new laptop not being able to talk to my receiver, I am forced to watch much of the content I normally use my laptop, directly using the smart features on my TV. Netflix and Youtube are the two most frequent ones I have used. I never bothered to use Netflix before but now I am bowled over not just by the content, but also the interface on the TV and the clarity is really really good. I still cant get my head over 4K - I tried breaking bad and it had lots of noise - may be all the extra clarity coming out. However 1080P on this TV really rocks - whether its Netflix or Youtube - clarity is way better than anything I have experienced before. The panel is really really good. Unless one keeps a Sony/Samsung/LG next to it - I see no reason why anyone would not prefer this TV
3) Its got 4 HDMI I think. I dont need so many. Its got ARC but my receiver doesnt. Hence havent tested it. Because of above laptop to receiver issue - I plugged a SPDIF out from TV into my receiver. So whatever content I directly watch on TV using its smartness - I do get 5.1 sound from my receiver. However when I connect my Laptop directly to the TV - the SPDIF to Receiver doesnt seem to work and hence I am stuck with sound from the TV - if anyone has a better idea please help me out or else I am forced to buy a new receiver
4) I tried playing my 8 TB WD RAID 1 hard drive/NAS..whatever its called - but TV wouldnt recognize it - maybe because the hard drive itself is smart and its got password and all that. I am currently downloading stuff on pendrive and will try it later in the night directly plugging it into one of the USB ports on TV
5) I downloaded couple of 10GB 4k movie rips - well its not bad - but I can see artifacts. Given that Netflix 4K doesnt have these issues..I am guessing these are the issues that happen when one tries to rip a 40Gb movie into 10 Gbs. And given how good Netflix is..I may stop downloading rips unless absolutely needed
6) I need to figure out how to play Amazon video on it given issues with my laptop and sound. Will try downloading the app and directly playing it on TV - hope it works along with 5.1 sound like Netflix
7) Tata Sky - I have an all channel subscription and normally I would think that full HD on Tata Sky is brilliant. However when I switched from watching Full HD on Netflix or Youtube and to Full HD channels on Tata Sky - one can clearly feel that Tata Sky feed is inferior - may be the compression used for transmission - its not that bright and vibrant as Netflix or Youtube. SD content looks ok. I would prefer watching SD content on my 720P Panasonic Plasma though
8) While I dont really watch out for bleeding of light from corners or blackest of blacks and all that - due to certain reviews by a reviewer called techibeez who highlighted these issues from Mi and other equivalent TVs - I actually watched out for bleed during full black - however I did not notice any such bleeding - havent had time to watch a full movie where its fully black - but reviews on youtube indicate this TV does good in this regard
9) I Played LG and Sony 4K demo vides and it looks really good on the TV. Although going from 1080p to UHD - very difficult to notice the difference. I guess if we keep two TVs side by side and play the same video..one at each resolution - then I guess we can appreciate 4K. Otherwise both look equally good.
10) The display is very bright..even after I toned it down a lot - its way brighter than any display I am used to seeing
11) Sound is pretty good too. Not really sure what Dolby or DTS means on the tiny speakers. However since I have a proper 5.1 setup - the sound on the TV is not worth comparing to a proper HT setup
12) The review units given to the top reviewers on youtube like igyaan seemed to be one from China or Europe which Roku and all that. Infact the unboxing from Igyaan had a white box with lots of logos on it. What i got was a bland brown cardboard box we normally get from Amazon with hardly any logos...hence this seems to be a made for India TV minus few goodies that people out of India experience
13) The TV has chromecast built in - so one less device to plug at the back. It works seamlessly - I need to check if playing say Padmavat on Amazon Video on my laptop streamed to TV outputs 5.1 sound back to receiver via SPDIF
14) There are some Videos on netflix which highlight it has HDR..again unless one has a display without HDR next to it..difficult to say if this works well or not. Same goes for micro dimming also
15) We got a long remote and a short remote. Pretty happy with them..I only use the basic functionalities though. One issue though on the short remote which acts as a air mouse...this is very hard to handle...I would rather plug a wireless mouse and keyboard as its been very frustrating to use. Other thing on the short one which works only occasionally is voice search - they need to refine it..
So I have covered playing from a computer, playing directly from the smartness, playing Tata Sky - not sure what I left out except games which I dont care - do let me know and I shall try and let you know my experience.
Overall I am really happy with my choice and havent really seen any cons thus far. Just hope it works well for at least 3 years - then it shall be fully paisa vasool.
On the TCL webpage..it says PIP..play HDMI video when you browse TV menu..not really sure what this means. Also one useful thing the Mi TV had was that it displays the latest channels watched from Tata Sky which one can control with the Mi remote itself...any idea if i can get rid of tata sky remote and do something smart on this TV too?
At the cost of repetition..Netflix and Youtube works really well on this TV. I have both wifi and an ethernet cable @ 100mpbs into this TV.
Sorry for the repeated edits!!
Really nice review Prasad. I am planning to buy one and this really helps.
Not sure if I mentioned in this post..I got some weird bars ...visible only when it was fully white...not bad ..but it was there..I complained and they replaced the entire TV. New one doesnt have problems. Only problem I have is with the smartness..its irritating to wait a minute for android to log on....I dont want any smartness since i use it with tata sky or desktop. I wish they had a way to make it a dumb TV and turn on instantly.
