subhashis_1980
All,
Need some help here.
I am using a HT system having Denon 1912 with Polk TSi300 as fronts(through bi-amping). Now, I would like to add a integrated amp using my existing polk speakers. Need suggestions here. connections are made from the amp to speakers thru Banana plugs.
Budget is a constraint here :sad: around 10k. can stretch at the most to 14-15k max. open to get a used system as well.
Heard Norge Gold 1000 could be solution, not sure though, need your observations. Does any FMs have tried this mapping.
TSi 300 Specs:
General
Type :Speaker
Speaker type :Floor-standing
Weight :26 lbs
Enclosure material :MDF
Features
Driver configuration :2-way
Woofer size (inches) :1" m, 5.25" m
Response bandwidth :35 - 25000 Hz
Input impedance :8 Ohm
Recommended amplifier power :20 - 150 Watt
Sensitivity :90 dB
Crossover frequency :2500Hz
Output features :Bass Reflex
Connectivity :wired
Thanks in advance
TSi 300 Specs:
General
Type :Speaker
Weight :26 lbs
Features
Sensitivity :90 dB
Connectivity :wired
Thanks in advance
