hi all,
let me start by thanking few FMs with whom i've interacted over more than a year regarding this build. Georgeo , SaikatBiswas , hifiramr and Sadik - buddy builder [sorry if i missed out somebody]. i haven't met any of them but still they have spent so much time over phone explaining/helping me in my understanding about the amps in general. hats off to spirit of DIY community :clapping:
now about the build. it's been almost 2 years that i decided to build this particular amp. it is very hard to document everything now as there is so much detail to cover. let me attempt it .. [most of the pics/text is from a different forum where my thread is posted - it's just easier post pics there . i'll try to link pics from there, hopefully it should work]
initially i was interested in building valve amps but looking at complexity and those alien bulbs i decided to stick to solid state amps. at high level, amplifiers per se are simple. dc power supply + amp pcb + heat sinks. simple! while looking for simple Class A amp build i came across Jean Hiraga's amp schema. it is based on an article published in a French magazine "l'Audiophile" by Jean Hiraga. not sure if it ever got commercially produced for general public. but there are few variations of the design out there with outputs of 8W/20W/30W.
it looked pretty simple with very few electronic parts on circuit and i read it needs high capacitance = 6 numbers of 20,000uF capacitors to build power supply. pcb was available on ebay. checked for availability of parts online and everything looked simple. so i'm set! first i procured the amp PCBs from Jim's Audio off ebay.com . i even posted a thread on diy section about the amp.
i kept looking for electronic components required for the amp. this went on for few months. finally, BOM on elements14 was huge. i was planning to buy double quantity of everything for matching purpose.
i finalized the soft start and speaker protection modules- bought them from theaudiocrafts.com
soft start has thermal protection built in, which cuts off the power if the temperature reaches 75 Degree Celsius [pic from portal]
2 units of toroidal transformers for power supply from Torotrans, Pune
since i was finding it difficult to source all the required components, i decided to order the complete kit from Jim's audio which includes supposedly 2% matched output transistors and hard to find driver transistors.
i actually assembled pcb last since i was concerned about my soldering abilities. i was worried that i might destroy the board or components because of heat.
few components soldered onto pcb,
caps:
0.1 F caps! 5 of them in the pic. humble Tata Sky remote for comparison. this was the most difficult thing to source in this entire build probably followed by cabinet build..
puny, 10,000uF ELNA caps against the monster caps!
Power Supply
this particular amp design needs one of the most beefy power supply - i mean really meaty! big not in terms of absolute transformer size or voltage but the amount capacitance required. i'm using little more than 5,00,000 uF capacitance in total per channel. in comparison most other amp designs might use total of 20,000 uF caps. so in total i'm using little over 1 Farad of capacitors for filtering and as reservoir. capacitors were one of the most difficult to source and costliest of the components in this build. online sources for caps were turning out to be very costly. then i started looking for local sources. contacted couple of capacitor manufacturers based in Bangalore. initially none of them werer interested in making/selling to end users. one of them routed me through their dealer in SP Road and the cost of those caps were higher than the online prices! after a month i again contacted one of the manudfacturers - Sarada Capacitors. somehow convinced the prodution manager to make 10 numbers 100,000 uF capacitors for me. but they would not sell it to me directly as they would need a TIN of a registered business entity. my cousin came to my rescue as he has a registered business and i got the caps billed to his firm. so voila, in couple of weeks my caps were ready!
[ignore the 5 caps for each bank, it had to be 4 in each]
later i realized that i made a mistake of ordering 10 numbers of capacitors. as i was planning for mono-block builds i needed either 12 or 8 of these caps so that all 4 rails will have equal caps! so in the end 2 of these monster caps are lying unused. but i had make up for lost capacity hence ordered 28 numbers of 'puny' 10,000uF ELNA caps.this also helps in dividing my CRC smoothing circuit properly and smaller caps after rectifier would not put load on transformer by limiting initial rush.
ELNA [visible in the pic only the ground floor of caps , first floor has been removed from box]
amp board needs input of around +/- 24VDC . there are examples of people building this amp with +/-35VDC too.
transformer rating : 400VA with 20-0-20 secondary.
capacitor rating: Sarada Caps- 100,000uf, 50VDC and ELNA Caps 10,000uF, 60VDC
resistor: Ceramic Wire Wound Resistor rated at 30W
CRC circuit: for each rail of each mono-block, after rectifier:
[2*10,000uF] + [0.25ohms] + [5*10,000uF + 2*100,000uF monsters]
testing power supply for the first time, you can see i'm wearing rubber slippers . probably looking at this contraption you might realize that it is not one of those slick build logs.
circuit includes a IEC filer ->soft start -> transformer -> rectifier -> CRC . output DC Voltage is 28.8VDC
caps:
Power Supply
