Lenco L70 - Help / Advice please
anilva can you tell me the model of the Denon tonearm? If it fits perfectly, I might consider this option. The lack of VTA and rigidity of the original L70 tonearm causes some inner groove distortion, and I think it's not optimal for the high level vinyl playback. I am happy with it, but if there's an easy upgrade path I would take it.
I have installed a Denon DP-790 tonearm. Most of the denon tonearms have 230mm mounting distance and suit L70. I am very happy with the tonearm and L70 combination. Now it looks it can play with better cartridges and new LPs.
Cheers.
Anil,
My friend who has a L 69 has purchased a AT 1007 tonearm for it. I don't know it's specs but my friend bought it after going through some forums about it's match for Lenco tables. BTW, yesterday I commissioned my arm pod with Jelco arm beside my L-75 . I just played a couple of LPs and not too happy as I have a Excell MC cart fitted on it. I had the cart for some time now and this is the first time I've tried. I guess it has to do do with compliance. I will try some other cart. I am seriously considering an Arm Pod for my SME 3012 early model with height adjustment system to be used on different tables. Now for a picture of the arm pod with Jelco arm
