Lenco rebuild with ARO Naim
Beginner_N
Pune
Hi All,
Finally I have my lenco. And just finished with 3D design of plinth with Peter top plate inspired design.
Now its time to get it cut.
Nishant
Top plate arrived today along with other parts. And bearing support as well. It's slow progress but moving smoothly.
I have just started my journey, my first step towards turntable. Below is my completed drawing of Plinth for Lenco L-75. The Process has just started.
lAh4BDmNWymnZsepzhM17VhOZ_DCBsSh2gGO1DIr2J31JL14zZoJ1_wHWdg3JLIMZD2b1eSVdw6d-aQM6vHQeU_RhMmYRrSC1m6jAJdYhhXen_VJVKdMDwusQnJTG3Nw8a6jLe-bObQe1HZ7YK8vBVsNFlRsAQwQVUsjP4aB_LOQZjd2uuMIRh1c7gvwTwWV7sbkZFoIiHAiP6GNh6aKhK630GEwdj_sTpze7dffHr6beBmgNllvZgXM9IVfDS5Q6I73m-RWVO313SMM-w7vs929_eN85M5SB_PsdKLvkaNSl_aPqUWisXURk2fIvWV2aHZAg4Zne7E23ItbpgRDtORwf6oMf37Mk4BdELNz9LugKMpNqItiyVVWJri4u64tdreRIOdT49-wz7RLWRvEIj0DKql3a4srdA4-105UXDIBieJGuDhb_3ulHU9zFdtOWKuIdz6fEsU_dvTXGpVW5hf08oYcRD6za5TDyZRi7RoPN5-HDirQeAY7LzqEJ20dgElkbNrOlYoM7B8azmk6Ln1LgulpdOB87JH9dfhqyvGEjpXK7sIN2gXaOqkf6A92xwdWeb6kru9KJ6Vh5hM1qA3Jtg9XJC9wEzI6SjQQDQC6wggM_lKY1Zzt2SvU2RE=w1862-h872-no
Sadik
CNC Router... Layer by Layer from 18 mm Plywood, Top & Bottom from MDF. Thinking for mirror finish on Top & Bottom MDF, PU Matt Black on walls of Plywood
Update
Its snail speed progress. But it's there. I finally got time to assemble everything together. Need some adjustments. 4mm sheet thick is too much and reduces gap between plater and base to zero. Need to machine bearing mounting area.
Finally paint and polishing.
very nice ! you seem to be using the PTP6. I am pretty sure the Naim Aro would be a fantastic combination with this !
One suggestion, wind some plumbing tape around the idler wheel arm to damp vibrations.
Is that a brass front plate ? I am looking for a brass or golden colored plate like this ( custom dimensions). Not particular about thickness and even 1-2mm are fine. Any pointers ?
Thank you!. Will use teflon tape on idler wheel arm. Its PTP 6 copy.
Naim ARO is on shelf, not finding good machining guy who can work on my tolerances, small size parts, quantity that 1 and price which is affordable. But I keep sending it for quotation, never know someone might do it. I will be using Ortofon SMG 212.
Its SS front plate laser cut. Brass sheets are available in 2mm.
Nishant
