LG CX Discussion (No Price Talk)
Here are my preferred settings (Apple TV 4K)
SDR - Movies
AI Picture Pro, AI Brightness Control and AI Genre Selection always off in any mode
Energy Saving: off
Picture Mode: Filmmaker
OLED Light: 70
Contrast: 75
Brightness: 48
Sharpness: 0
Color: 50 (adj as per preference & color profile of the movie)
Tint: 0
Advanced Controls
Dynamic Contrast: off
Super Resolution: off
Color Gamut: Auto
Gamma: 2.2
White Balance
Color Temperature: Medium
Method: 2 points
Point: High
Red: 0 (adj as per preference)
Green: 0
Blue: 0
Color Management System
Red & Blue (leave other colors at 0)
Saturation: 0 (adj as per preference)
Tint: 0 (adj as per preference)
Luminance: 0 (adj as per preference)
Peak Brightness: off
Picture Options
Noise Reduction: off
MPEG Noise Reduction: off
Smooth Graduation: off
Black Level: Auto
Real Cinema: on
Motion Eye Care: off
TruMotion: off
*Once back on Picture Mode screen “Apply to all Inputs”.
SDR - TV Shows (Apple TV 4K)
Energy Saving: off
Picture Mode: ifs Expert (Bright Room)
OLED Light: 75 (to 80 depending on the show)
Contrast: 75 (to 80 depending on the show)
Brightness: 48
Sharpness: 5 (or 10 based on preference)
Color: 48 (adj as per preference & color profile of the movie)
Tint: 0
Advanced Controls
Color Gamut: Wide
Gamma: 2.2
White Balance
Method: 2 points
Point: Low
Green: 0
Blue: 0
Color Management System:
Red (leave other colors as default)
Saturation: -5 (adj as per preference)
Picture Options
Black Level: Auto
Real Cinema: on
TruMotion: user
De-Judder: 2 (or 3 based on preference)
De-Blur: 10
OLED Motion Pro: off
SDR - Documentaries (Apple TV 4K)
Energy Saving: off
Picture Mode: Standard
OLED Light: 80
Contrast: 80
Brightness: 48
Sharpness: 0
Color: 50 (adj as per preference)
Tint: 0
Color Temperature: W7
Advanced Controls
Dynamic Color: off
Color Gamut: Wide
Gamma: High1
Picture Options
Black Level: Auto
Real Cinema: on
TruMotion: user
De-Blur: 10
DV - TV Shows & Movies (Apple TV 4K)
Energy Saving: off
Picture Mode: Cinema
OLED Light: 83 (70-75 for movies)
Contrast: 80 (75 for movies
Brightness: 48
Sharpness: 0
Color: 50 (adj as per preference & color profile)
Tint: 0
Advanced Controls
Dynamic Contrast: off (Low for dark shows like Sabrina on Netflix)
Color Gamut: Wide
Gamma: 2.2
Color Temperature: cool
Method: 2 points
Point: High
Red: 0
Green: 0
Blue: 0
All colors
Saturation: 0
Tint: 0
Luminance: 0
Peak Brightness: off (Low for dark shows)
Picture Options
Black Level: Auto
Real Cinema: on
TruMotion: user (off for movies)
De-Judder: 0
De-Blur: 10
DV - Documentaries (Apple TV 4K)
Energy Saving: off
OLED Light: 80
Contrast: 80
Brightness: 48
Sharpness: 10
Tint: 0
Color Temperature: C20 (adj based on preference)
Advanced Controls
Dynamic Color: Medium
Color Gamut: Wide
Gamma: Medium
Peak Brightness: Low
Picture Options
Black Level: Auto
Real Cinema: off
TruMotion: user
De-Judder: 3
De-Blur: 10
Is there any way to see which resolution a movie is being played on when using Amazon prime app? Also is there a way to remove black bars above and below when watching content from Netflix app? I see same black bars on Amazon prime as well.
Hello FMs.
Ive got the CX65 installed at my home in Port Blair, finally and Im loving it.
I wanted to check if a stabiliser is required for voltage protection or the SMPS would do ?
I should mention that the voltage in the islands is notorious for fluctuations because there's no power grid and the entire island pretty much runs on diesel generators, so constantly there is switching. Would it be advisable to get a stabiliser to protect the expensive investment rather than no protection at all? If yes, please suggest a good voltage stabiliser for the Cx65.
I used his settings for C7. It does improve skin tones and evens out colours in general.
Made a few minor changes to 2 pt and 20 pt WB by looking at solid colour slides (black to white) to remove any colour bias/tinge. Looked fantastic.
Real Cinema to On for movies.
Well I just use ISF Bright Room preset for SDR, which looks good to my eyes with little colour popup and Cinema home/ Cinema for HDR content
Hello FMs.
I think TV do have voltage surge protection in higher end TV. But why to risk? I got V Guard Digi 200 in Amazon, it is 6 amp one. got around 3.5k Ya 6 amp is a lot. it will more than enough for 65 Inch and all the stb, consoles, hometheatre.......
Last Night my CX55 went kaput. Wouldn't turn on, Pressing on button on remote or Tv caused a white flash for a micro second followed by a clicking noise.
LG Technician arrived today evening and said Motherboard needs to be changed and they don't have that in stock. I asked for a replacement.
Tv was connected to APC 600VA UPS since its installation and it had done close to 60 hours. I didn't even get time to game on it.
Lets see what LG does now.
I think you need a stabilizer. Ups alone is not working as I realized it myself, as the problem is with high voltage that can arise in winter season as most don't switch on their ACs. In an area if less load is consumed the high voltage likeliness can just bust your boards. Ups can handle low voltage but not high voltage.
Digiguard 200 6 amperes I have it too! And I have a 75" TV plus sound bar fit to it.
Hello FMs.
Like someone said V guard 6amps Digi 200 with volt meter led display. High voltage is converted to 215-230 volts and is 100% recommended.
Is the top and bottom black outs due to different aspect ratios, a danger for image retention? For the individual pixels switch off for producing those blacks, while the other pixels are always on - is this good or bad for an OLED TV?
My LG 65CX also makes the clicking noise when I turn it on. Is this something we need to be worried of? Or is this a common behaviour which is observed by all the owners?
After waiting for a long time, installed LG CX65 yesterday. As per suggestion by many people I attached it to APC Back-UPS 600VA. Suddenly, the UPS power off/on button turned red and blinking. I switched off TV as a precaution. Should I continues to use the UPS? Does any of you have any idea why it's happening?
I followed it up with APC customer care and as per them, Back-UPS 600VA is not suitable for connecting to a TV. Right model for connecting to TV is APC SUA750I-IN and it costs around 12k.
