Looking for 5.1 speaker for Sony Blue ray player
nileshsangani
I have latest Sony Blue ray Player & now i want to conver it to 5.1 home theater system. Suggest me good spaeker system along with Amplifire/
To stay simple you can go for a Sony / Onkyo 5.1 System at moderate budget. If you plan to spend few lakhs than the combination is almost limitless.......
budget and the room area would be the initial imprints to get an idea what wo do justice at your place..
room dimensions and budget..
and if you are only looking for speakers.. then logitech..
else go the htib way
You have bought a Sony BDP, which means it can process lossless audio formats, which means you should prefer an AVR that can process MA and HD audio, which also means some searching in the forum for the right brand and model that suit your budget and taste.
