D
		Deleted member 15865
Guest
What is your amplifier placed on? Are you using stock feet or any isolations? Sometimes (especially with budget amps) putting folds of cotton towels under the feet could tame the highs and also some of the boom if it’s coming from vibrations travelling back into the amp. Doesn’t cost trying. Needs some experimentation though. If your speakers and amp aren’t absolutely mismatched (they don’t seem to be), then with speaker placement and isolation/vibration control for amp one would be able to get it to sound right. Of course the sound signature remains - but usually one gets used to one’s signature as long as the rig is sounding right.
Finally, if you still resolve to change the speakers, as a Castle Knight user I’d support the recommendation already provided by two FMs above as well-built speakers with ‘warm’ signature in the budget and matching with the amp.
