regeHA
Re: Raspeberry Pi Set Up Issues!
Also, remember to enable DLNA server in moOde settings. You can wirelessly stream and compare how it sounds in comparison to HDMI.
Have a play around with the moOde options/settings at http://moode/.
@terrible - Plug in ethernet initially (that's what I remember reading somewhere, to use ethernet for the first run). Login/pwd to access internet is not an issue, just enable DHCP server in the router and the Pi will be assigned an IP. With moOde you don't access the internet, just the local network. Ditto for access and configuration too.
After installation you need to login to moOde via browser at http://moode/.
Follow the instructions at http://moodeaudio.org/docs/tcmods-readme.txt.
You do understand that MoOde is a headless OS and at the end all you will get is the command prompt on screen, which is what i see in the pics. Looks all good.
However in order to use wifi first you have to connect the LAN cable and boot and see if you are getting an ip from the router. Poweroff the rpi, plugin the lan cable and wifi adapter and then boot again. Once you reach the prompt type ifconfig and see whats the ip under eth0
if you got the ip you need to go to a PC connected to the same LAN as Rasp Pi and in the browser type the ip of Rasp Pi or http://moode/ . this will open the moode interface. Click on settings (top right), then configure and then network.
Under the WLAN address type the SSID, Security you using and Password and click apply. This should start the wifi dongle working. Now IMP step ....power off the rasp pi (settings then turn off), once its completely shut off, remove the LAN cable and power on Rpi again. This will configure the device to use wifi via dongle, once its booted, type ifconfig at the prompt and see if you get ip under wlan0.
