Sorry for hijacking your thread terrible
But I needed advice from fellow members which is related to the topic you started
I have an option to use a raspberry pi or a PC with daphile for my music server
Which should do a better job?
If chosing either of them does not make a huge difference I will opt for a raspberry pi as it consumes lesser space
Hi Sam
Thanks a lot. Will wait for your daphile review
I will be using and am using the raspberry pi with moode audio as a player
I am currently using my father's PC running minimserver as an audio server. It has a modest amd cpu but a good power supply
I already feel the sound has improved with using an audio server with raspberry pi vs connecting a USB hdd to raspberry with all source material
In both cases dac is same and using coaxial output from raspberry pi to dac
No worries.
In fact after reading your post, I installed minim server right now on my MacBook Pro which in flat two minutes turned into a music source for me. Wish I had read about this before. Maybe I wouldn't have to order even the Raspberry Pi. But I still don't know the quality as it is difficult to play loud and long at this time of the night. Also the music file was from iTunes so of lesser quality than the flacs played through Raspberry Pi. Will test for quality tomorrow.
Just a question. Why do I need a DAC here if the CA Connect is throwing the file to the AVR DAC?
Hi Sam
No worries.
Hi terrible
I am not sure how CA connect works. If possible can you provide little more details
Don't discount the Raspberry Pi. In fact you can install MinimServer on the Raspberry Pi itself and shutdown the MacBook Pro when not in use. In fact all of my PCs and laptops are no longer part of the entertainment chain. I stream everything off an external NAS and use a Raspberry Pi, a tablet, Chromecast, Roku, etc. I am planning to add something like Cubox TV or Cubox for video playback/Kodi.
Because you want to use a better quality DAC? The AVR will at best have a single chip DAC solution that is mid hi-fi at best.
@terrible ..... dont wast a complete macbook on installing minim server. If you like minimserver (which frankly I did not), you can use another Rasp Pi for the same. Mind you there are loads many different ways one can have music server running, you have to see which is best for you.....
For your video needs try the orange pi plus 2
It supports 4k playback, has a faster cpu and 2 gb ddr3 RAM and host of connectivity options
Just my two bit on Kodi for video. I have been encoding blurays for a while. I have stopped now because it bores me and anyway I can get top notch encodes done by others privately. Kodi is a very average player in its visual output, do try and use MPC-HC with madVR it is just far superior. Yes you won't have the fancy cataloguing of Kodi but far better quality pic especially when its thrown on to a TV.
Is there some sort of guide on how to set this up? And are you currently using this and if so what is your review?
No if you are satisfied by minimserver by all means continue. Other then minim you can try AssetUPnP or Twonky, all are DLNA based music servers. It was just my personal preference, I did not like Minim coz it its less features or the way it works. Also I dont like to keep the server UPnP complaint, instead the client (player; you can say) should be UPnP capable.(so that I can push music to it via any other UPnP based player) Server should concentrate on other server intensive tasks, like for example Transcoding, downsampling, ripping, conversion, cataloguing. Of course serving music in all its original glory is also utmost imp.
You cannot connect/use MoOde player with Daphile, both are based on different tech. Daphile acts as squeezebox server (SBS) and can only be "read" by squeezelite or squeezeplay based player like PiCorePlayer.
If you want to test Daphile, then you can use your fathers PC to install Dhapile or any other x86/64 based machine OR I think Daphile can also be installed and run from a pen drive. You then have to ditch MoOde and install PiCorePlayer or squeezelite on Rpi and then stream music over it.
If this looks too much of an effort, just keep using MoOde.![]()
Restart MoOde .....
Suddenly moode.local is not showing on Chrome. It just says 'Webpage not available. The webpage could not be loaded because: Proxy Error'.
I have absolutely no proxy set up. And this opens fine on Safari, just on google chrome. Any idea how I can rectify this? I have done all kinds of cleaning of cache and flushing but to no avail.
I have experienced similar issues with moode and that's one thing I dislike about it most
If there is no issue from browser side, cut short your work and reinstall moode
The article describes all the options with Pi that I am already crying out loud on all threads ...lol![]()
