spirovious
Offtopic but how much you paid for 500 GB HDD as i am looking for 2.5" internal HDD along with 2TB 3.5" HDD.
I got mine WD Blue for Rs.2950,but got for someone last month WD green for Rs.2650(internal)
Very good rate is it for 3.5" desktop or 2.5" laptop as i want 2.5" laptop ones.
Yah,perfect i think so,wht ever u say man,philips is best what i think so,even i have a philips TV and its good,have been using that brand since i was young,:clapping:![]()
Have anyone asked about the history lessons here,what i said was we have been using philips and its worthy ok
Hello Spiro,
, or just water, and what about the cover for the LCD TV?
Thanks for the quick response...
1) I am still unsure how this DVI thing works, will have to spend some more time googling. So do you mean that you play a DVD movie in your PC and set the resolution using your nvdia graphics card to 1024p in your PC, then you have a DVI out pin in your PC which connects to a DVI to HDMI converter PIN, and that cable is then connected to your 5609 using an HDMI cable, right?
2) & 3) I dont have an nvdia graphics card on my laptop, so the things you've done I wont be able to do, so I will have to wait until I get the WD TV Live, in the next couple of months, to do DVD upscaling etc. I can do upscaling in WD TV Live right Spiro?
4) I do have VGA out pin in my lappy, but not sure of DVI. WIll check it. Is there a VGA to DVI converter available, like the HDMI to DVI pin you're using?
5) I've noted down the VGA mode settings you've given, will try it tonight.
i WaS MORE INLCNED TO go for pana x10 or x9 than philips 5609 as i already have pv8 plasma. This one i was looking for my parents room.
But seeing the reviews , i am inclining towards philips 5609. My pv8 decision was purely based on reviews in hifivision and team bhp and to this date i am happy with it as i just went and bought it without doing any checks.
Looks like i might buy 5609 similar way
Net_CMD , can you please where did you buy for 32.5K ? was it in bangalore?
