DXing - remind me of SINPO test of shortwave stations. (Signal, noise, interference, power, overall) One would submit the reception results (by giving numbers 1 to 5) to the radio stations. They would send some literature/stickers and stuff. Radio Nederland sent me some nice shortwave antenna booklets. But no longer have them.One big news to me. I was never expecting this. Though I never intended in FM DX'ing it is happening. I am clearly getting FM 100MHz from Ahmadnagar and little weak Mumbai 92.7MHz big FM in morning time.
Thanks apk! Get it from me whenever you visit here next time.
Great acquisition OM.
Best regards.
Update -
100MHz (Ahmednagar) is available clean till sunrise + 30 minutes
92.7MHz (this is Solapur & not Mumbai) is available till 8:00AM
103.7MHz (Satara) is available for complete transmission, noisefree & clean only from sunset to sunrise. Though my antenna is pointed exactly 90 deg from direction of Satara, this is surprise to me.
Hi rubensm, I could not read those pictures, please provide link to some hi-res pics. Also I could not understand that sketch 'B'. Please explain a little bit. But TV antenna does not help much for FM remote stations.Have a quick question, i receive some week signals from srilanka FM stations and moderate signals from Tirunelveli FM stations at home. I use a NAD 402 tuner with a 2 ft long piece of ordinary flex-wire connected to the line pin of the antenna socket. Dug into my garrage yesterday and located an old folded dipole (from our old TV antenna). Was wondering if I could build an antenna for FM reception. Don't have a long folded dipole so was wondering if the approach (in diagram B) will work. Plan to use 75 ohm co-ax cable, but also have the 300 ohm tv ribbon cable available. I am sure I'd need a balun if I'm using the 75 ohm cable. Kindly comment. Thanks.
with reference to the antenna/balun design and photographs:
Nice design, some gurus of TV Dxing back in the 1970s used to swear that electrically isolating the elements (directors, reflector and dipole) from the mounting beam produced better results. In your view, is this the case?
That wooden mast is 1.25"X1.25" cross section 75" long piece from teak wood. After all drilling I soaked it into wood primer and 2 coats of oil paint. IMO that electrical isolation is helping me out there.
That would work, folded dipole can have joints. Only dimensions matter.1) cut off the corners of this folded dipole and extend the length
That makes it wide band by adding half wave dipole. less directional and less gain. It would help to receive FM. Though I am not sure correct impedance and connection for that arrangement.2) add two horizontal elements to the existing dipole (as explained in illustration B). Back in the 1980s, I have seen some designs with double dipole (one under the other) and was wondering if this arrangement could be used
This may help youAlso, what are your views on the vertical yagi vs the horizontal yagi for FM?
We have local 5 FM stations in Pune,Total how many FM stations being received on the FM Tuner with Yagi?
I filled that pipe with rangoli (fine sand will also do). Closed both ends with cotton. Then I used 1/2" GI pipe to put slow strokes and bend it. Each corner took good 15 mintues patient work. Later removed that filling. That filling saves it from caving in/denting of pipe inside.Hello Om, I was looking up this article today and curious how you got the dipole bent into shape. How did you pull that off?
Actually I wished to buy this tool, even one DIY effort was tried with wooden planks. But I felt it was done with patience. If this some cheaper then I can make all sorts of yagis.That's great work.![]()
I thought you used a tool like this one:
Hi ,Hello Om, I was looking up this article today and curious how you got the dipole bent into shape. How did you pull that off?
Hi ,
We can use the spring generally available at Refrigeration store , which is used by them to bend the hollow copper pipe.
This comes cheap,
Vipin.
