Hi again all
Very good morning.
Please note that this is a very long post. And I felt the context had to be explained before I get to the solution part.
I've been having my pmc speakers for almost 2.5 years now. They go very deep in the bass. In my untreated room they go to 23hz at -3db, at my listening position, when I measured with REW 2 years back. Sounds awesome right. Will not need to faff with a sub for that below 40hz content that we all yearn for to get a full range audio spectrum. But in a domestic room, they have been a nightmare to tame that deep bass which excites all the room nodes ( as it goes so low it excites the length, width and height nodes as well ).
They sound splendid on EDM and punk etc..which is modern music with computer beats which start and stop on a dime. But play anything from indian Bollywood tracks with real drums, that have bass decay that goes real low, and it was nightmare with all the nodes again making their presence felt. So this was something I really wanted to adress.
I proposed room treatment to my wife, which was promptly shot down. So I had no recourse but to play with speaker positioning and DSP.
Then i read the article by audiopro titled " a king was crowned today" , which filled me with hope that proper speaker placement could help me here. ( My very special thanks to audiopro and prem for that article )
I was travelling when I read that article, so waited till i came back home. And played around with the speaker positioning along those lines for the last 4 days. Used 2 tubes of moov already
Now with the right positioning most of my bass gremlins are gone ( I couldn't exactly follow that rule to a T. The inner edges of my speakers are now placed at 1/6th of the width of the room from side walls as 1/3rd was too narrow in my small room
.And the front baffles are placed at 1/5th of the length of the room, as 1/3rd would have moved them too ahead and constrained walking space. ).
But the 2 below Hindi tracks were still a pain to tame :
1. Dil diya gallan from tiger zinda hai
2. Agar tum saath ho from tamasha
They both still sounded very bloaty with very undefined bass.
Now some flash back...
Since Iam a bass monster, I tend to listen to lots of bass heavy tracks at night. And my downstairs neighbour came knocking a week back.. So i felt i had to decouple my speakers from the floor if I had to continue listening without bothering my neighbours. So decided to place some marble slabs on my thick carpet and place my speakers on top and see.
So I went marble shopping. And finally ended up with 8 marble tiles of 15x15 inches. To decouple each from the other, I bought the below soft rubber mounts from Amazon India.
Now I placed 4 rubber mounts between each marble tile, and placed my speaker on top with spikes. Now when I even touch the speakers , the entire marble stack along with the speakers rocks back and forth and sideways. Just the way the townshend isolation platforms wobble in the vidoes that I have seen.
So finally got down to testing those 2 tracks. And I just went WOW.... I was getting solid tight deep bass. But this is at my normal listening levels. It could be that at this volume the room nodes are not getting excited. So will have to wait till tomorrow to see if this arrangement even works at loud volumes, as room nodes are room nodes and have nothing to do with speaker isolation.
But at my normal listening volumes the change has been so dramatic, that I wanted to share my findings immediately.
Below are some pics of the isolation podium Iam using. Iam sure that removing some of the slabs will change the sound as per taste. So something worth experimenting for others with bass problems.
My costs were 600 INR for the 8 marble slabs and 750 INR for the rubber isolating mounts ( I bought 3 packs, that is 9 per pack
And i use 4 between each tile.. Except between tile 3 and 4, where I use 5 nos. With an additional rubber mounts in between )
Thanks for reading such a long post
Edit:
Felt the above post was incomplete. So posting the below as well.
I'm not alien to speaker isolation. I had tried them with some oehlbach XL air springs ( which presently still do duty under my tube.amps, for their excellent decoupling ability ), which did tame the bass a bit , and add more detail and clarity in the mid range and treble. But it softened the bass too much., by which I mean there was more bass texture and definition, but less in your stomach impact.. And as I am very very particular about bass depth and impact. I decided not to use isolators on my speakers, and went with spikes into thick carpet..
So much so that I didn't even bother to take the trouble of trying my isoacoustics gaia3 isolation feet, as I feared more of the same effect.
But I will try them this Sunday and report back..
But I feel the present arrangement where the speaker is coupled with one heavy marble tile with spikes. And then the marble tile is sequentially isolated from the floor is delivering better benefits. Just my 2 cents.
Thanks again for reading
Just in case anyone wants to follow my placement, my room dimensions are as under mentioned.. I'm quoting in cms, as measured by me
Length = 459 cms
Width = 347 cms
Height = 264 cms ( with false ceiling)
So if other member's room dimensions change, then they probably have to interpolate or extrapolate accordingly.
Thanks again for reading my long drawn rants
Very good morning.
ajile Clear Recessed Adhesive Bumper/Foot 22 mm Diameter 10 mm Height - 9 Pieces - BIP069-RC: Amazon.in: Home Improvement
www.amazon.in
Edit:
Length = 459 cms
Width = 347 cms
