My simple wooden rack
Shivam,
Congratulations on a job well conceived and finished. You have a beautiful and functional rack.
My current rack initially was basically the same as yours - made of solid wood (higher grade CP teak), but it became too tall (needed to hold all my equipments). But now, before moving to my new place, I decided to make two identical looking racks by cutting the original one into two and making the necessary additions/changes.
The only difference with yours: I have left more space below the bottom shelf so that the floor underneath can be cleaned easily, and the now the finish is dark (done with Asian paints melamine). You can see the pictures in this post: http://www.hifivision.com/my-audio-video-setup/31476-now-whoz.html#post432613 .
Initially I had some rubber feet attached to the bottom of the wooden feet touching the tiled flooring. But I was not happy with that - somehow I feel the stability of the rack depends on the quality of the rubber. In any case, my racks are very heavy, and as such wooden feet do just fine IMO. If one one wants to be fancy, one can think of spikes, but in Indian conditions with concrete buildings, spikes may not be necessary. Only tricky issue is the leveling - one should make sure the racks are properly leveled (i.e. horizontal).
I also cover up all my equipments with soft pieces of cloth - cut into small pieces from a length. In my case they are grayish light blue in color. However, one should use the covers only when the equipments are cold and not in use - most important for amps, especially my tube amp which can get really hot.
Regards.
The covers may take away from the pleasure of gear gazing, but, as long as the mentioned thermal guidelines are kept to, I'm sure it will protect the equipment.
We have a not-often-used laser printer, and it has been covered with a tea-towel, when not in use, since we bought it. Our house is in a very dusty area: the printer still looks as good as new. If that dust is not getting to the outside, there is also going to be less getting to the inside.
I'm getting the idea to do the same for the hifi myself :)
I tried taking a photograph to show how the shelves are set into the posts. The posts have a square socket with an 'L' shaped part left in. The shelf has the corners made to fit into this socket. This is a view of a corner of the top-most shelf.
(Sorry for the poor photo quality. This is from a mobile device.)
Recently removed the vibrapods completely and tried only with the cork pads. The sound remained the same with all except the turntable. On my earlier metallic stand, I needed vibrapods under every component. Now on this wooden rack, I need them only under the turntable and for the remaining stuff cork works well.
This rack is made out of teak wood completely. Weighs a lot and suits my requirements.
This is such a beautiful rack. Even I am also planning to build one for myself.
The fabric is black cotton cloth which my wife forced me to buy from a handlooms outlet. She then herself stitched them double layered.
Great effort from the wife. :clapping:
Nice to be reminded of that lovely rack. I hadn't realised about the home-stitched equipment covers. That is a really good idea: I'm sure that keeping the dust out increases the life of the equipment. Well done, Mrs Shivam :)
Pictures are usually linked from photo sharing sites like photobucket. They will be visible here as long as the photos remain in the original location. Folks often delete old pics.
Looking for heavy duty rack for my audio system as my amplifier is about 34 kg and preamp about 24 kg and many other equipment from heavy to very heavy.
Can any one help ?
Santosh
