^^ mate read first...i said "afaik"...i didn't claim anything!.....ok,i should have put a official disclaimer if u wanted that!.....but can i know on what grounds r u straightway refuting that it is guaranteed Non-spva panel,just because it is a budget model?....what alternative panel according to you should the cx32 have then...TN panels?
Honestly i have Not come across any sony lcd/led tv with panel lottery issue registered in india yet...The general idea is that,Sony has so far refrained from doing lotteries with their panel & usually gets their spva panels from joint S-lcd Spva Panel venture,since thy have a stake there & profitable to source one.Morever Cx(Connected Series) is Not the lowest Starting Lcd tv range from Sony,that distinction goes to the Bx(Basic Series),the starting line of Sony lcd tv ,where u may doubt,if u want to!...still i believe in Sony more then the rest to put the correct spva panels in their lcd tvs & the overall consenus at HFV & others is also about same!
btw,i dont have the cx32 to check out the panel, but have the cx42 & i allmost know for certain(Not from its service menu,its complicated to decipher[google doesn't help],but the general display characteristics u can find out if u r careful enough, to notice difference between amva & spva)that it's a NOT a Amva or other cheap panel but a SPVA only! If u closely follow my threads,i myself was a samsung lcd panel victim & experienced there & can now allmost visibly identify if it's a Amva or spva. Here is my Samsung Amva(aa) problem thread >
http://www.hifivision.com/televisio...i-get-guaranteed-samsung-spva-sq01-panel.html ,if u didn't find that.To tell you honestly,i have No such issues about the cx42 & so i'm hopefully sure it's a spva panel only! Anyway,coming back to the Cx 32 ,i feel Cx42 & Cx32 are quite similar models probably sharing the same panel type,one being HD & the other being FHD!... & that's the Best Bet from me for now of telling u & all that both cx32 & cx42 have spva panel for the tv!
At the very end,i would just say if u like ur tv(pq etc) & know about all its features, & dont have any videophile issues, u really don't need to get so hard on what panels u get,... ur tv is NEVER perfect!
