Audiodoc
I am talking of the 2009 models. At that time HDMI were not as ubiquitous on laptops as today. You can google to confirm from various forums.
The 0.08 is from a non dimmed zone or with dimming off since in a dimmed zone it cannot be measured and thats from televisioninfo who have the Sony measurements taken at their settings of 400Cd/m2+.
To measure the black level of the display, we put up an all-black screen in DisplayMate and measure the luminance at the center of the screen, in candelas per square meter (cd/m2). We measure the black level at several times during the testing of the display, then we report on any variance we see with these multiple measurements and we discuss any dynamic backlight or local dimming that the display uses that affect the black level. However, the main figure that we quote is for the black level at our calibrated settings, with the backlight on maximum for LCDs. Our score is based on how dark the black is: the lower the luminance, the higher the score.
Even Realta or Marvell don't use 3 core processor which is used in oppo bluray player so how the hell philips cooked up a three core processor themselves...:lol:..I am gonna laugh for atleast a week.
It was pretty obvious what i had mentioned,which is televisioninfo measuring done a 400+ cd/m2.So in a non dimmed zone thats the measurement they got with full backlight setting.Exactly, but you assumed this : The 0.08 is from a non dimmed zone or with dimming off since in a dimmed zone it cannot be measured
Ideally setting the back lighting to max while displaying a black image should not effect the black levels, the same way setting the cell light to max should not effect the blacks on a plasma.If we don't get decent blacks when a black image is displayed in an LCD while the back light is set to max then i don't see any advantage in local dimming.
If one reduces the backlight to ideal conditions or for night time viewing the blacks measured by television info will be much darker.
So today i've learnt if back lighting is set high darker colors will appear lighter and lighter colors will be washed out:lol:
I will pass over these golden words to television info and many other reviewers.
Don't twist my own words.I don't know where you cooked that one.
In layman term a lcd has a color filter typically a RGB layer and TFT layer which blocks or allows the light,when its blocking the light that when you measure the blacks,now without the backlight you won't register any reading ,if you turn on the backlight when its glowing at its lowest around 100cdm/2 to its highest around 500cd/m2 there will naturally be a variation in the blacl level one you change the backlight.
Television info is the only website which tests a full on or off contrast with the backlight setting maxed out.
Contrast Ratio
To calculate the contrast that the screen can achieve, we divide the peak white luminance by the deepest black luminance they can produce when showing normal video and not in a standby mode. So, if a display has a deepest black of 0.4 cd/m2, and a peak white of 400 cd/m2, the contrast ratio is 1000:1. Our score here is based on how high the ratio is; the higher the better. Note that our tests differ from the approach that manufacturers use to determine the contrast ratio; they test the peak white with the backlight on full, then the deepest black with it on the lowest attainable setting (often called a dynamic contrast ratio). Our test determines the true contrast ratio with the backlight on full during the test (often called the static full field contrast ratio).
For direct view LCD and Plasma displays the ANSI checkerboard contrast ratio is generally within a few percent of the full field contrast ratio above. Reviewers that find a significant discrepancy between the two are in instead measuring the veiling glare light contamination of their measuring instrument instead of the HDTV. See below.
Tunnel Contrast
The tests above tell us about the performance of the screen showing just pure whites and pure blacks, but not in the more real world situation of mixed white and blacks on screen.
Some displays have problems here: with these areas of high contrast, the whites bleed into the blacks, making them appear brighter than they should and reducng color saturation at the same time. To measure this, we do a test where a variable width outer rectangular frame on the screen is set to peak white, and we then measure the luminance of a small black area at the center of the screen to see how much light bleeds to the center as the frame expands closer to the center.
Some other sites have a much simpler test using a checkerboard pattern (and refer to this as checkerboard contrast), but our test gives much more information on how the increasing amount of white bleeds into the black area.
Other sites also forget one important technical aspect of this test: that having white on the screen can lead to some of the light from the white screen area reaching the measuring instrument and creating an artificially high reading for the black (a problem called veiling glare, which produces very large measurement errors that lead to erroneous conclusions).
We avoid this by using a special black Duvatyne mask to block the white areas of the display; any light that reaches the measuring device has come directly from the center target on the screen; not from the surrounding area on the screen.
The score a display gets is based on how constant the black level remains; a constant black gets a higher score.
 Thread starter wants to decide between 2 LEDs. Can we help him?
Everyone knows how LCD's work(it's there in Wikipedia), don't know why you deviated to how LCD works.
from what you are saying, when back light is set to max on a local dimming LCD, the local dimming system wont adjust itself in favor of the content it displays, it will rather continuously glow and show poor blacks even when a black slide is being run on the screen, so this obviously proves local dimming tech is simply useless in real world usage.
Over all we have to stick to the black levels by setting the back light to the lowest although this black level has no benefits in real life usage of LCD TV's.
here is how they measure contrast.
How We Test TVs - TelevisionInfo.com
I mean kudos to television info for giving in depth detail on how they actually measure unlike most sites.
A local dimming display will dim and even brighten depending on the content shown
Post the same in avsforums or avforums so that they could LTAF.
If and only if its a local dimming tv would adjust ,the placement of the probe matters and whether the same zone has some a image or content displayed .I know how local dimming works, i was just being sarcastic there.
Then setting the back light to high should not be an issue if local dimming takes care of the LED's depending upon the content displayed.
If you again cook some statement against this then you are contradicting to the statement you made few posts ago.
Its a knows fact plasma's have low brightness but it is real brightness and much higher than any LCD panel with no back lighting help, hence i said plasma is a real display while LCD is simple handicapped and always needs the help of back lighting.
You should post your thoughts on how one should measure contrast and blacks and prove telivisioninfo.com wrong, AVS might not LTAF
