Need home theatre for 40k
Its not the question of hearing.....you need to actively search or wait till something shows up ......,which fits your budget.......
This is what is available....
https://www.olx.in/item/sony-muteki-home-theatre-ID1le12d.html#5c071e9601
Check the specs online and audition to ensure it meets your expectation.......
If your budget can stretch....this is what is there on hifimart
https://www.hifimart.com/denon-x540bt-wharfedale-dx-1se-5-1-speaker-package.html
HT Store Bangalore has some offers being their 8th Anniversary.....hurry up...check....decide as stock would be limited......
https://htstore.in/index.php?route=product/category&path=165&sort=p.price&order=ASC
All the best
All the best
Thanks efernandi for your suggestion
I have seen the olx and audition is not available and the price is not negotiable "sony muteki" very good system my friend already own it very good in surround , hifimart really out of mt budget htstore its around my budget but i have to see is it reliable to buy from HTSTORE https://htstore.in/index.php?route=product/product&path=165&product_id=522
AVR with jbl 610 has to decide which AVR suits the best combination
Some of our members have purchased from HT Store...i have not yet seen any bad comments or negative feedback about HT Store.....
You can also refer to some YouTube videos to see & hear reviews about the speakers and the possible AVR you would like to pair it with.
Yamaha AVRs are good....if paired well with good speakers, it will be a decent experience for sure.....
You should go for Yamaha 2910 instead of Onkyo 3800 IMO. I recently auditioned both the systems and Yamaha fares much better mainly because it has an active subwoofer as compared to the passive one on Onkyo. As far as bluetooth is concerned, you can buy a simple aux to bluetooth attachment for less than 500 from anywhere. My dealer is giving the Yamaha package for 39k and onkyo package for 34k. So please negotiate your prices accordingly...
Entry level.....AVR X500 is an old model.....latest is X540....
If you are fine with an old AVR model which meets your connectivity and performance requirement then go for it....
The speakers are full range basic ones.....see if you can chip in more money for a little upgraded set of speakers.....ensure they are 2 way speaker design so you get better clarity and performance across the tone spectrum of frequencies..
Ok then I have another offer Denon x540bt and definite technology pro 600 5.1 for about 60k
There is not much left with Yamaha YHT-2910 active subwoofer. It is anyway under powered subwoofer so no matter it is active in it.
I felt a huge difference in bass when I compared the two side by side using same content. The Yamaha had much more bass as compared to Onkyo 3800. Yamaha 2910 is much better than Onkyo 3800 IMO.
Yamaha 2910 bass output is better but I used to hear cracking sound at audition in reliance digital and surrounding sound seems to be not present
Yamaha 2910 has natural sound and it's brighter in sound and punch is not present and surrounding is not that great
Never audition on reliance digital! They have pathetic speaker maintenance and keep all 5 speakers in the front together. They can make even Snells sound like shit.
Need to buy good surrounding speakers with AVR for my 25 inch pc monitor my budget 40k need suggestions in buying I don't know much about AVR having confusion of AVR failure need suggestions in that too
Since its is a 25 inch monitor I wont suggest huge speakers around as you wont be sitting too far away from it. Big speakers get advantage when placed wider. The problem is the distance between center and Left and right channels. it will be too close at your optimum viewing spot. If its just for PC I would not go with speakers which has drivers more than 4 inches.
I'm still considering the Yamaha
Yes, I'm not going for big speakers and I won't change my monitor another one year I used to see only movies and 5.1 surrounding songs I'm been out of playing games because I'm not having time for it and want system that can be connected in pc monitor through HDMI from graphic card
I'm not going for big speakers and in a budget to do so short listed
1) Yamaha 2910 -40k
2)denon 550bt and sys2020 5.1-50k
If budget permit
Onkyo 5805 for 63k
Denon 550bt with Polk t1600 for 67k
how about jbl bar 5.1 its available for discount for 44k in reliance digital
can i get true 5.1 surround through hdmi
Assuming you are talking about JBL sound bar 5.1.
I have ZERO experience with quoted JBL model.
If you are selecting JBL, you are limiting your future gradual upgrade options.
Since surround is battery operated expect a battery charging hassle with JBL on and off on that particular model.
Better stay with AVR and seperate speaker config.
Purely imo.
Atb
