Hi All - Just wanted to clarify if 32 W550A uses AMVA or SPVA Panels..??Howz the PQ on SD..?
Has one got an hand on 32W550A ? Howz the performance..? Is it true that this model has bleeding / clouding issues..??
Just confused - should I go for 40" or 32" with W550A . Which one would be better to plunge in...
PLZ Advise with expert comments and experiences...
well the W series appears to have a SPVA panel,PQ is great by far the best 32inch lcd,SD content is good but it will look a fraction less sharp then a HD ready tv like the S550A,but the W550A makes with higher contrast and motion resolution.
as far as clouding its like a lottery,if ur luck is bad u might get a tv with clouding issues,even if clouding is there 90% of the people will not notice it unless u are sitting in a room with No or dimmed lights,even then its only if u hunt for it , in a scene that is pitch dark .
