need suggestion on high ceiling pj screen and quality
ayushwas
bangalore
Hi, I am looking for a screen for my new living room which is 9 ft high. i want to mount it on ceiling, just behind false ceiling. so, its not visible when retracted. room size is 14 * 20, so viewing distance will be around 13 feet. projection calculator says i need 120'' screen 16:9 ratio.
it would be better if i could find a screen with drop height, so i don't have to break my neck. Since, i couldn't find any i was thinking to buy a 4:3 ratio screen, so the extra height serves as drop.
Also, based on quality of screen, should i go with elite screens or Inlight/cineview are good enough. For example, below are the two i considered, one is elite with SRM around 10 k, the other is inlight motorised around 15k. Since, its one time investment what would be the right option around 10-15 k budget.
https://www.amazon.in/Elite-Screens...coding=UTF8&psc=1&refRID=M0HAGG176EB2JZ5JZ147
https://www.amazon.in/gp/product/B0...9-b270-44de-9fcc-5cf0a06a7727&pf_rd_i=desktop
