need suitable speakers for denon 2800h
slkr
chennai
Hi , Could you please advise which speaker will be champion with denon2800h. i have planned to go for below segment series due to budget but try match best one.
elac debut 6.2
polk es20
q 3030i
elac debut 6.2
polk es20
q 3030i
Suggest you audition the speakers you have shortlisted with music and movie content you are familiar with and take a decision. What sounds good to me may not sound great for you. Listening is very subjective.
Best to audition and decide. if budget is an issue, makes sense to look at pre owned ones.
Are you planning to buy just front left and and right, or a full 5.1 set ?
Amongst the ones you have listed, I have used the QA 3030i with my Denon 3700H AVR, and I was happy with the performance.
I am using IndiqAudio Diamond Mishra LCR with the puny Yamaha HTR-2071, and the performance is good. With better AVR, they will shine more. If possible, do get their audition.
elac debut 6.2
polk es20
q 3030i
I have a question - why have you chosen your AVR first, and then your speakers? I think it’s usually better to do it the other way around because speakers are a better investment. Speakers last much longer as they are passive, and also AVR technology changes quite rapidly so I’ve always preferred choosing my speakers first and then finding an AVR to match, keeping in mind I’ll keep upgrading my AVR every few years
