Ok. Everyone needs best bang for the buck. Lets not take things personally and constructive criticism is always good
I will try to tell what my requirements would be - it might fall into NAS or it might fall into HTPC with a big hard disk. I do not mind what it is called and these are in layman terms.
1. A storage space which can be turned on 24*7 primarily to use in my home network. I intend to copy all the FLAC files and Blu Ray rips on to it.
2. This needs to be expandable as I add more data, say I start with 3 TB and can go upto 12 TB in a couple of years time. I should be able to use my external hard drives as well.
3. My father who do not have much idea about booting up the PC and all should be able to play music from the shared location via my Squeezebox (when I buy
). So the squeezebox server should run on this.
4. My AVR can access movies over DLNA but might not support or play most of the formats. So if I can save some money to to access these files and output to my AVR (assuming the device sit near to my AVR) it will be awesome. All digital outputs and audio pass-through upto 7.1
5. I should be able to play music in my room while someone is watching a movie.
6. As this is going to be the only place the files are saved (only music and movies .. I do not intend to copy my docs .. for that I can use google docs free of cost and I do not work for RAW
7. Can I access my music files over internet while I am abroad? It will be great!
8. Looks are not very important but the size if kept the minimum would suite me fine.
I have another question - if I have a Router and powerline network at home, will his setup work just at home if I do not have broadband enabled? I might have asked some silly questions - bear with my ignorance.
