Norge 2060
RAJUSH26
pimpri
Hi friends,
Pls advice,
Stereo amp suitability,
Norge 2060 or any other for pairing with,
Sony hifi system front speakers 6 ohms ,1 kHz
I have Norge 2060 with Sony hifi system speakers of 6 ohms. Works pretty well.
Me too using Norge 2060 with sony bookshelf speaker;
Speakers are from MHCGX - 2000 system.Small config amplifier like norge 2030 also works fine with speakers .Mail your speaker specs to Norge email id given on website or u can always carry your speaker to Norge Mahim Demo room if possible.
Hello friends , my Sony hi-fi system MHC-VX90AV BOUGHT IN the year 2000 and is running grt except the solders r failing often now and I have soldered them quite a many times . But time has come for a new amp.
My TWO FRONT speakers specs are
MODEL - SS-VX90AV
4 way , 5 unit bass reflex type , magnetically sheilded.
Woofer. 17 cm cone type
Centre tweeter . 5 cm cone type
Side tweeter. 5 cm cone type X 2
Super tweeter. 4 cm cone type
Nominal impedance. 8 Ohms at 1 KHz
120 Watts RMS POWER OUTPUT Reference.
Weight - approx 5.5 kgs each .
10 % THD
Will the Norge 2060 /1000 be a good amp for these speakers.
R there any other better alternatives in the same price range .
Norge amp does not have a FM TUNER , any solution for this.
Look at amps from DNM also. They have built in tuner / usb/card slot options as well
If you set on Norge, then 2060 is their best integrated amp.
My 2 RS.
I emailed them nd they have suggested 2
the A 777. 125 rms
And the A 8080 U. 80 rms
Which is better.
We have been dealing in DNM amps since a decade. Originally they were being
manufactured in India and subsequently they have been imported from China.
The present models build look and performance and pricing are very reasonable.
With DNM amps for the last ten years the repairs are very very low.
the A 777. 125 rms
Which is better.
Go for the 777. FM Sean D'Silva has recently bought the same & is very happy with it. You may PM him for more queries w r t its performance.
Booked the DNM A777 @ pankaj , PUNE . HOPE TO GET IT IB 2/3 days . Don't know how will it pair with my 125 w SONY HI FI 12 yrs old front SPEAKERS.
Got it for 13000 INR.
Haven't yet recd my DNM A-777 amp . Hope to receive it today. The price was jacked up recently and I got mine for 15760/-.
Hope it performs well.
Hello guys at last I recd my DNM A-777 amp , nd WOWGUYS IT HAS JUST LIVENED UP MY 12 yrs old SONY HIFISPEAKERS . THE INTEGRATED FM IS A GOOD ADD ON (missing on Norge ) , will post photos after I have settled with the placement.
norge 2060 available in odisha!!!
yes it is with Chandan Enterprises, shop no 144, ispat market, sector 14, Rourkela.
price is at a higher side. one can have an audition of it before buying it from Mr. Bajaj, Mumbai.
try simple circuits for listening music. FM add-on to an integrated amplifier is not at all a good choice if u r a music lover and love purity. if need FM then go for a fm tuner indeed.
