square_wave
The dynaudio sound with the dynaudio woofers and the esotar tweeter sounds very different from the usher. What one likes depends on what they are looking for.
I listened to the Luito floor stander from Sonus faber on saturday. What can I say ? I found the speaker to sound fabulously "musical" ! Enough to make one shut up and just listen to music. It is a sure cure for "audiophilia" for most people. Will everyone like this speaker ? I am not sure ! Hence there is no point in arguing. For some it is theil and bryston combo while for some others it is a proac and some tube amp ! I have realized that for most music lovers, it is a matter of what combination sounds good with the music that they listen to most of the time. I am sure a lot of loudspeakers out there are designed this way too.
Measurements will not tell you how a loudspeaker will sound. It just give you an insight into its behavior in the anechoic room which is a good thing of course.It helps as a good reference point to start from. Cabinet construction, driver material/technology, crossover components, time and phase alignment aspects, the designer's "vision" about the sound etc...will all finally affect the sound. As long it satisfies someone, it is good enough.
  So hoping that the next best option i.e Accu E 450 + Thiel CS 2.4 works for me.
