Oled C8 pixel damage started in under 1 year
I have one question. The tv was on desk till now. Wall mounted it roday using lg's ez mount full motion wall mount. After the installation, the engineer pushed the tv back to the final postion putting complete pressure at the centre of the screen. Is this safe?? Considering the thickness of the panel can it withstand that force??
The right way to do it is to push from the corners of centre and top or bottom with the top or bottom just for support and most of the force given at the Centre and not the middle of the screen.
Ok got it. Yes i also knew that was the correct technique. Hope no internal damage happened
I have also registered a new request for the grey patches at the edges. Lets see what happens
Ok hopefully they should replace. Just fight that the panel is faulty
