One for all -universal Remote
Congrats! Enjoy your remote. It's a wonderful technology.
Thanks a lot.
I got the remote today and have configured it to work with Tata Sky and my LG LCD TV.
I had a question. The logitech packing says that it can control 15 devices where as i downloaded a manual from internet that says it can control 10 devices. Now which is correct one?
If you are little creative you can get this remote to do wonders for you:-)
Also, can you please give me an example? It will help me.
Thanks a lot.
525 can handle 10 devices. 880/885 can handle 15 devices.
In the night I watch movies with dim light. So when I need to take a break or interval, I just need to press a custom button (on screen) "Interval On"
This "pauses" the movie and "increases" the room lighting (IR) by 3 steps.
"Interval Off" button does the vice versa.
I needed to configure a custom button with a sequence. For "Interval On" I have defined the sequence as:
1. DVD Pause.
2. Light +
3. Light +
4. Light +
So you can configure a good sequence using any device(s) to work some magic:-)
Anyone tried 525 as HTPC remote?
Without getting HTPC remote,by remote codes & IR device ,is it possible?
I purchased a Harmony 525 remote from ebay.in for 2990/- shipped yesterday and it arrived today. (Used a discount coupon and it came to 2.8k)
It is a sealed piece overstock sale from sumeria.in.. Came with VAT paid bill and warrenty..
eBay India: Logitech Harmony 525 Univesal Remote - Sealed - 30% OFF (item 290409282271 end time 03-Mar-2010 12:58:00 IST)
Aparently the seller did not update the number of items and the listing ended prematurely after my purchase.. Mailed him and got a reply that he has many pieces left for the price and will list them shortly..
Have a look on ebay in the coming days.. This price is unbeatable..
Congrats! And good info!
Whats the model for Airtel DTH box?
Also the vendor??
I found SUN DTH and TATA sky but am unable to find airtel in configuration s/w for 525.
Can we turnoff Harmony 525 with cells inside just like mobiles?
I found cell drain faster eventhough you dont use remote.Can we switch off remote?
I tried pressing power button for a moment,which is not working.
hey this generic remote sounds great i just want to know whether it will work for an A/V reciever...actually i have a
Technics SA-R177
Quartz Synthesizer AM/FM Stereo Receiver.
but its quite old, i lost the remote...sope just wanna know will these remote work with it?
may be i buy tem and it wont support....
plz help
but its quite old, i lost the remote...sope just wanna know will these remote work with it? may be i buy tem and it wont support....
plz help
Logitech has built up a library of codes for literally every electronic unit in the world. I even found codes for amplifiers that were manufactured over 12 years ago.
The best way to find out is by going to their website.
Technics SA-R177
plz help
Check here.
Logitech Harmony Member Web (members.HarmonyRemote.com)
P.S: I checked and it is supported.
Most of the universal remotes come with a charging unit. You leave the remote on the charger when you are not using it. That should be enough to keep them charged for your usage.
Guys, i need a solution for my hifi components. I have :EHP 606, Bada amp and MHZS Cd player. Is there a way to integrate the three remotes into one single one ?
The Logitech universal remote should work.
Check Blasto's [post=120804]post # 155[/post]
Charging unit?
I dont have that,but now started using rechargeable uniross batteries.
