one more question on HDMI
balajeem
Chennai
Hardwares: HDTV (Full HD)
Sony Upscaling DVD Player
AVR with HDMI (Specifically Denon 1610)
If I take the HDMI out of DVDP and connect to HDMI in of A/V Receiver, and then connect HDMI out of AV to TV, will audio also come via HDMI ?
Source that will be played: Normal DVD in the markets and mp3 songs , audio CD
What's the diff between 1910 and 1610 apart from the wattage ?
what's HDMI passthrough vs Full HDMI ?
When I play source (normal DVD, mp3, audioCD) from upscaled dvd player, I need just the HDMI cable out of DVDP to Denon 1610 . This will get me both audio and video in single cable, right ?
Denon 1910 does what this upscaled DVD player does .
Is this right ?
Right,you need to set DVDp audio as HDMI.
Usually DVDp/BDp upscales better than AVR(1910).So you need not worry.
Usually you can see in DVDp menu > sound outpu> then select HDMI(other options can be Coax,2ch stereo etc)
