If anyone really interested in buying home theatre and they need the best then they should not buy the basic model ,if price is the concern instead buy something cheaper for 5-6k homrtheatre need not spend 25k cos you will not be satisfied even after buying it I suggest buy one by one system good one like denon receiver then klipsh speakers , sw ,try to buy it by emi you will not be burdened and the quality of sound makes a lot of difference
