The connection you gave is correct.
STB HDMI out > AVR HDMI in
AVR HDMI out > TV HDMI in
For surround audio you can connect the SPDIF out of your STB to one of the SPDIF in of the AVR. Then you can assign this spdif input to the HDMI in of the avr where you will be connecting the STB.
Hi, one more help pls. on the above set up, how to connect bluray player. Can you keep bluray player connected to tv simultaneously when stb is connected to tv. If so how. Expert opinion pls?
Why, HDMI does not handle surround audio??
It is a problem with the HD DTH box. Most HD DTH support surround audio through spdif only.
Oh that's really sad.
i was also going to order an SPDIF optical audio cable. i had a simple query. should i go for 1 meter, 2 meter or 3 meter length? i am asking this because i was thinking that a long cable might disrupt the signal and it might be unable to pass through correctly because of higher attenuation...i was wondering whether this is true for optical cables or not...please guide.
also should i go for normal non-branded cable OR something branded like Belkin etc.?
i was thinking which port should i use to connect the HDMI from my laptop to AVR's HDMI INs, as the TV/SAT would remain permanently occupied by the stb. will it make a difference if i plug it in bluray or may be cd in?
What you are talking about is TV/SAT HDMI IN in the AVR. ARC has nothing to do with HDMI Input ports of the AVR. ARC works on the HDMI OUT of the AVR.oh thats much of a relief!..thanks. i was concerned because i read that for ARC to function we need to have it plugged into the tv/sat slot, so i thought other ports might as well be having some peculiarities.
I bought for 24k from ebay alongwith a 500gb hard disk as a gift. Superb deal guys, do check it out and sound is amazing. Delivery was prompt by tnt.
We bangalorians are not getting any offers on Onkyos.
Every time it is on a fixed price of 25K
All those who are getting at 3-4K less are from hydrabad, mumbai, delhi, chennai and coiambatoor.
And i have seen Onkyo only in Modern world.
Edit: Just saw this offer in Ebay 3400 for 23,700.00
New Onkyo Home Theatre 5.1 Channel (HT-S3400) !!!Lowest Price!!! -Warranty | eBay
I have bought HTS-3400 from same seller and it is already shipped on Fri by TNT courier. It should reach by Monday.
Though i bought it for Rs.24000 but I also used voucher for 500GB HDD. I could not get good prices in gurgaon-was quoted 25K, so 24K with bill and warranty and 500 GB HDD worth 2.5K was best deal. You can also have a chat with dealer - Mr. dhruv and buy from ebay.
Donnt know why I have been recommending eveyrbody to go via ebay
