First i need a good amp setup for near audiophile range and power within a good budget , i am planning to start with pre power combo for pure two channel music listening, then i will be upgrade my speakers.There's Schiit Vidar at 700usd, 100 wpc which I'm using. You can bridge as monoblocks to 400 wpc of course at 1400 usd. The issue will be getting it from USA and need to send back to US if you need service. Advantages will be, It uses less noisy El Core Power Supply, Class AB against Class H of Emotiva . For Boston A360 100wpc should be enough in my opinion, but higher amplifier power is mostly good and liberates you while planning future speaker upgrades. The preamp options from Schiit for Vidar are quite VFM as well. I went with Vidar because of the impression I got from listening at FMs place, my experience with schiit products and clear upgrade path which is in my budget.
Stereophile noted slight distortion in XPA Gen 3 according to this review, and was suggesting proper speaker matching for better performance. Most other reviews have been quite positive.
https://www.stereophile.com/content/emotiva-xpa-gen3-two-channel-power-amplifier-measurements
Always better to listen for yourself and decide, since these measurements don't necessarily translate into real world experience.
Another option is professional amps( Qsc & Crown), Class D in the budget, which will be much cheaper and provide the same or better amplification power. My listening of them is with professional speakers in a Party environment hasn't been pretty good from audiophile perspective ( there's bias against them which is not correct). I am looking forward to listen to one in my room environment with audiophile speakers.
You can go DIY route with experienced FMs like @Aniket or experienced people locally , who can design a pure Class A tailored to your power requirements,
which CLASS type (A,AB,H,D) is good for power and SQ ?
