Pass B1
Hey buddy, I'm a game for it. Do you have the PCBs? Let's start a group buy.
I have already given Gerber files to Sachin.
This is layout which I designed couple of months back.
And this is where I used it after selected source and before Pass B1
Initially I used LSA with SSP. But faced problem with the CNC OPAMPs which were going to protection mode whenever I was changing the selector switch. Then as per Om's advice removed the LSA frm SSP to B1(usual way) & it solved the problem.
Hmm, you guys are using an active preamp and providing gain to the signal and then using the LSA to again limit the gain to control volume.
Noob question here. Is it not better to take the signal from the source straight to the B1 and then take it to the active preamp?
Either way will do, but B1's output impedance is exact 50 ohm, ideal for audio RCA cable, same thing is not true for active SSP. So B1 will drive any power amp happily while both can sever good input buffer near source. Only LSA lowers impedance if visible to source.
Ok what is its OP impedance?
I had recently connected my Marantz CDP to my class D power amp through the LSA. Music came through but when I increased the volume control beyond 90%, the amp went into protection mode. Did I do anything wrong?
Somewhere it was documented ~70 ohms.
No it's perfectly okay as you fed your power amp till it went into satuaration and subsequent protection. Maranz CDP has output level higher than other sources. Either reduce gain of amp kit if provided or leave it like that. [Adding 12K in LSA input is not so good solution as it will reduce gain to half for all sources.]
Actually, I intend to make a B1 and mate it to Class D power amp. I also wanted to make the power amp with two options:-
1. To be used directly as a power amp.
2. To vary it's gain by routing the input through an LDR through a second set of RCA plugs.
I haven't thought about this impedance matching thingy. Do you think that the idea is workable?
How does a pot avoid this issue.
what is the standard use case for an lsa. is it anyway supposed to be used with two preamps like we are discussing.
Not sure whom you are referring to but coming right after my post, I presume it is my post.
LSA, (Light Speed Attenuator) or LDR (Light Dependent Resistor) is a wonderful way of getting a potentiometer out of the signal path.
I'm unable to understand how it is "supposed to be used with two preamps"
Pot used as volume control has general values above 47K, which is impedance source sees. Here two LDRs in series and shunt operated as volume control shows ~13K which should be ~25K.
Two preamps means two buffers? IMO it look like you are referring both buffers as preamps. That is good idea.
Om,
Can you post the final schematic of SSP that you built? I saw some posts on audiokarma where you stated that you got rid of output coupling caps.
I am planning to build this by point to point wiring. Do you think this will work fine? Cause the circuit seems to be pretty simple and will be powered by the Pass B1 power supply.
Hello Sachin,
I would also like to have one too. If you also have the parts, then even better. Let me know. I sent you a PM regarding this.
Om,
You can easily build it on temporary board as shown in above PCB. If you add 1M, 1/4W resistor from input to ground then output DC offset is 0.3mV for AD823 OPAMP which I tested. That makes 2.2uF caps redundant and can be omitted.
BTW, you need to supply dual PS (+,0,-) to this where Pass B1 has single PS rail (+,0).
