Best impedance mach for Nelson pass B1 what should be the best value for the power amplifier ????? so we will get maximum detail from the source.
If you do not have impedance matching issues
jai1611 said:Passives are VERY system dependent
How would I know? What are the symptoms of impedance mismatch?
The B1 doesnt have impedance issues with most power amps. It still does need a high gain power amp though.
Any specific budget in mind for the power amp?
What I was observed that In creek A 50ir Integrated amplifier.The sound is very details and beautiful and the pre is passive.When I was used same creek passive pre-out with NAD 303 power amplifier the sound was totally dead nothing in it.But when it comes with integrated sounds awesome.
I have heard same with exposure 2010 first edition it have passive preamplifier it sound very good also we connected its pre out with bryston power amplifier its sound very attractive than integrated.So what I think is the exact matching between pre & power even if it is integrated too....
I am in the same league..I am getting Pass B1 for testing my system in Pune.
If it does not work, then would go for IFI-Itube Preamp. If you live nearby Pune, the you can check the same on my system.
cheers
dheeraj
Do you mean highs? lows? Or all, as in not able to produce volume?Among other things, sound gets rolled off.
How nelson pass B1 on the highs it will be good on low and vocal what about higts is it good
B1 is very transparent and does not constrict any part of the audio frequency.
It is strongly advisable to perform the simple resistor modification described elsewhere on the B1 build thread on this forum.
In my experience, it has rock solid bass, rich mids and very well extended and liquid treble.
I have heard that for head-phone amplifiers to headphones too
Remember that if you are using the Passive Pre Amp section of one Integrated ( say Creek) to feed another Power Amp (eg NAD) there will be an extra pair of interconnects, with their Cable Capacitance.
If impedances are not matched ( as will be typical for a passive pre) High Freq loss will be the First casualty
Input Impedance: approx 13 kohm
Bufferred output impedance: 250 ohm
Passive output impedance: varies with volume settings, drops as volume increases, 0 at max volume.
When using the PASSIVE output, be certain that the total cable capacitance of the cables is less than 1000 picofarads per channel
Electrical Characteristics:
Capacitance, conductor to shield: 12.2 pF/ft
Resistance, center conductor: 34 ohms/1000 feet
Resistance, shield: 1.7 ohms/1000 feet
Input Impedance: 10 k ? unbalanced, 20 k ? balanced
