spirovious
do you still have it?
.Ps.check PM.
Thanks kapvin,
Can you tell which key?I have installed PowerDVD7 & may try for solution.
I DL pure video ,but new drivers are slow/heavy on my old GC.Still it works.
It retails at an MRP of around 2800/- INR. But if you go to a local store you may be able to get it for slightly less. The wired one can be bought for an MRP of 1699/-.
in which case the ps3 BD remote would make a lot of sense. I got one and now I use it with my main HTPC using a key mapping software. works perfectly with both powerdvd and tmt. (needs different key mappings)
works without needing line of sight is so is actually really good for my application where the pc is tucked into a corner
price - less than 1500/- plus a BT dongle (do they cost more then 200/- now?)
Hey that's an awesome idea. But is a bluetooth dongle all that is needed for the PC to recognize the device?
