pendrive sized pc
it would have been great if it had a hdmi male so that it could be inserted directly into the TV. But then the remote may not have worked.
hmm better the HDMI is female , spend 200Rs on cable , as we will hook USB hub kind of things , HDMI part may break if they get pulled ;)
the world is changing and you can go using your cell as desktop ...
Here one guy uses the galaxy nexus as pc ..
Using a Mobile Device as a Desktop Computer - YouTube
some detailed writeup here ---> Link
Starting with Honeycomb on tablets, and continuing with Android 4.0 Ice Cream Sandwich (ICS), Google has started adding the features to Android for it to be a desktop replacement. With a few cables and some peripherals, you can run a desktop-like experience from the Android 4.0 phone that rides around in your pocket.
