Philips HTS5550
Suggest you to increase the budget slightly and get Yamaha 196. It should be around 20K and comes with lots of connectivity options.
Yaar lo mat, saral aur spasht bhaasha mein varnan karo
Please post in English else you may get warning from the Moderator.
THD - Total Harmonic Distortion. For a good system it is less than 1.
For Yamaha it is 0.06%( 1KHz, 50 W/ 6 ohms)
For Philips it is 30%
When a signal passes through a device, additional content (noise or distortion) is added at the harmonics of the original frequencies. THD is the measure of that. So when a signal passes through Philips AVR 30% of the signal get distorted whereas in Yamaha it is only 0.06% (for 1kHz, 50W) which should be close to 5-6% on entire spectrum at rated power.
So in layman's language, you won't be able to hear dialogue properly. The music and sound effect will not be pleasing to hear.
