alladinkachirag
Possible. Let me try reducing the file name length.
Any success??
If that is an issue with the file extension case, then wouldn't it also work if we just rename the file "somesong.MP3" to somesong.mp3"?Guys,
Plz chk those songs in u'r PC with file extn nomenclature. Sometimes downld songs have extns as .MP3 (UPPER CASE). If so then convert these songs using Jet Audio Premium or any other software to .mp3 ( lower case ). Just a simple conversion to mp3 would make them to .mp3 ( in any bitrate of u'r choice).
Once I faced this problem in Itunes where IPOD classic could not play the songs with .MP3 extensions.
Try this if it works.
The problem lies somewhere else. I have downloaded an entire album which uses the same conventions for naming each track and still some tracks are unplayable. Will try reducing the file name length today. Couldn't do it yesterday; reached home late![]()
I reduced the track name to just one character; still it refuses to play.
...i tried 192 bit rate or variable bit rate it refuses to play.....
For me VBR plays without any issues. It is just that some of the tracks are rendered unplayable...
I have also faced the same thing in 610. if your mp3 ss 128 kbps it will play without any problems. i tried 192 bit rate or variable bit rate it refuses to play.
