Platter damping rings
arj, it has grooves between the markings / etching of the speed strobo indicators. Steve you're on to audition that FU 50 amp tonight. Anyone else in Bangalore want to come over to listen to this amp paired with my gear?it may be a bit of a disappointment as there seems to be a technical mismatch to start with.
I re-checked my 124. A gasket will interfere with the brake lever. Also even if the brake lever can be ignored, the platter doesn't protrude enough to take two gaskets. It will take only one. Ditto the L75. Guess I will have to play around with the tonearm horizontal weights only.
