PlayOn!HD Media Player Review
i and my friends are using the Play on box .
The results are amazing picture clarity . For a 12K its really worth . I have also heard from friends that the Xstreama is noisy , doesn't support all features of AC RYAN on hardware
AC- Ryan Play on HD New firmware update
Copy install.img to the root directory of a USB flash drive and connect it to the USB host port of the player.
Enter the Setup menu, System, System Update, System Upgrade and Enter to confirm.Please wait for the flashing to complete until the Playon! HD restarts by itself.Do not power off the unit during the flashing process!
The HDMI connection may reset after updating the firmware and may go out of sync with your display.Press the TV SYS button on the remote a few times to sync with a compatible display mode if this happen.Once the display is back, we recommend setting to HDMI Auto in the video setup menu unless a manual mode is preferred.
Attention:
Please note that version v7.0.6 r2233 is based on the latest SDK version 2 and cannot be downgraded to earlier versions.Should you need to roll back to an earlier version, you will need to reformat the internal HDD through the Playon!HD system.
Model:
AC Ryan ACR-PV73100 Playon!HD
Version:
v7.0.6 r2233
Release:
2009-11-06
Firmware History
New Features / Improvements / Bug Fixes
Version v7.0.6 r2233
What's new in this release
1) Add HDMI LPCM Multi-Channel support
2) Add DTS-HD Master Audio pass-through support
3) Add Dolby Digital Plus pass-through support
4) Add 16:10 option for Aspect Ratio
5) Add Ken Burns effect for image viewing
6) Add Seamless Playback for image viewing
7) Add torrent download function in Home menu
- Place .torrent file in any folder and press Menu to select "Add the torrent"
- On-Screen real-time download status
Press Menu button on selected torrent download to select priority level
Press Stop button on selected torrent download to Stop torrent or Stop torrent and Delete file
- On-screen client setup
8) Add Internet Feeds function in Home menu
- YouTube streaming
- Picasa photo album
- RSS news feeds
- Flickr
9) Add mounting of attached USB storage present in network
10) Add BD-ISO playback (more BD-ISO functions in development)
11) Add NFS support for mapping of network folders
12) Add Screen size calibration to fit video to screen
- Press ZOOM IN button of the remote control during playback to fit to defined screen size
13) Add Network Host Name configuration
14) Add Japanese (S-JIS) text encoding
15) Add Korean (EUC-KR) text encoding
16) Add Thai (TIS620) text encoding
17) Add system time synchronisation with time servers
18) Add external USB DVD-ROM support**
19) Add Auto-Play function when a disc is inserted in the external USB DVD-ROM
20) Add Parental Control for disc rating
21) Fix reboot action when the power button on remote control is pressed
22) Fix lip-sync with DTS audio in 23.976fps video
23) Fix punctuation order of Hebrew text encoding
24) Fix internal subtitle in MKV to display according to default flag
25) Fix internal HDD capacity information correctly above 1TB
26) Fix Simplified/Traditional Chinese characters display under English Language Menu
27) Fix external USB DVD-ROM unable to eject once mounted
28) Fix the extra directories present when returning to Home menu from browser
29) Fix system freeze when another USB device is attached while the wireless N dongle is in use
30) Fix internal Simplified Chinese SRT subtitle present in MKV container format
31) Improved playback of files in sequence via network
32) Remove File Copy and Setup menu from Home menu
33) Remove unicgi (Neighbour Web) application from Extension Info
**Due to CSS (Content-Scrambling System) present in DVD movie discs, the system accepts only un-protected DVD movie discs.
Version v7.0.6 r1757
1) Add subtitles menu
-Subtitles selection (Internal & External)
-Realtime Text Encoding
-Time Sync
-Colour (White,Black,Red,Green,Blue,Yellow)
-Size
-Position
2) Add Media Library function in Home menu
3) Add chapter mark support for MKV videos
4) Fix playback glitches when internal subtitles are switched
5) Improved playback and audio sync with 23.976 fps videos
6) Improved Info details on the current played file
7) Improved Simplified Chinese text encoding for subtitles
8) Improved wireless connectivity with 802.11n USB adapter
--Currently developing--
1) Add external USB optical drive support
2) Add Auto-Play function when a disc is inserted in the USB optical drive
3) Add Parental Control for disc rating
Version v7.0.6 r1402
1) Add support for Bluray PGS subtitles support
2) Add message when USB host port is plugged in
3) Add highlighting of next music track in Music playback mode
4) Add hidden WIFI SSID support
5) Add subtitles position (up, down) and font size (left-decrease, right-increase)
6) Improved Internet Radio layout
7) Improved network connectivity after resuming from standby
Version v7.0.6 r1135
1) Add PLAYON!HD screensaver;
2) Add Simplified Chinese menu language;
3) Add Russian menu language;
4) Add Simplified Chinese (GBK) text encoding;
5) Add 1080p 24Hz option;
6) Shift Browser to default selection in main menu;
7) Shift file info to the top of the screen during music playback;
8) Change VENUS network name to PLAYONHD;
Version v7.0.ACRYAN.r647
Initial firmware release[/LEFT]
Play on HD has capacitiy to add 2 TB internal HDD . This is 3 1/2 Inch SATA HDD. Not sure if this is supported by Xtreama
Only for interested members, non-interested members please ignore, do not read further and crib later on.
Just upgraded to the latest firmware. Tested for DTS-HD-MA, works perfectly fine. But no support for DD-TrueHD yet.:sad:. Dolby Digital Plus is also working fine.
Subtitle option are cool (size, position, color).
Will post more info about other features after testing.
cheers
I was also wondering regarding the usb wlan adaptor would help if we can get costs on it too
Play on comes with HDMI High quality cable . This alone is worth around 1.5K INR
play on HD is now available in India thorugh its distributor AqTronics technologies . They are based in Bangalore, have offices in Delhi , Mumbai , Chennai & Bangalore . This box i am told will also be available through resellers shortly
Play on HD - with HDMI Cable from AC Ryan
The HDMI Cable provided with the box is also from AC RYAN
AC Ryan sells 2 .5, 10, 15 mts cables .
The 2Mts cable provided with the box is itself worth 1K INR .
How is it comparable?
PlayOn is 13K
XTreamer is 10k
WD TV Live is 7K (WD TV is 5.5k)
PlayOn is the costliest
Iam in the process of acquiring a HD DVDp with usb playback and am narrowing down on Philips 3388 for ~5k.
I already have a divx DVDp without USB and HD and the only problem is writing DVDs (and maintaining them). Given that this player takes care of my DVD needs, can I get an WDTV instead as it is only marginally costlier?
Where can I get WD TV for 5.5k in Hyderabad?
Edit: Bangalore or chennai location is also fine.
Blasto: I think you should post this in the WDTV thread so here we focus only on Playon. I dont think WD is available at local shops at that price (Chennai i think its 6.5k from Delta Peripherals), you need order from 20north.com.
Continue further Qs in WD thread
Play on HD from AC RYAN - latest firm ware updates
Note:
Attention:
Please note that version v7.0.6 r2388 is based on the latest SDK version 2 and cannot be downgraded to earlier versions.
Model:
Version:
v7.0.6 r2388
Release:
2009-11-17
Firmware History
Version v7.0.6 r2388
2) Add DTS-HD Master Audio pass-through support (Playon!HD decodes internally to PCM)
- YouTube streaming
[Due to legal implications, this function is temporarily on hold]
[Resource:http://digital.limberis.com/2009/11/wheres-youtube-on-popcorn-hour.html]
- RSS news feeds
- Flickr
9) Add search function for internet radio
10) Add WEP (HEX) and WEP (ASCII) option for wireless security
11) Add mounting of attached USB storage present in network
12) Add BD-ISO playback (more BD-ISO functions in development)
13) Add NFS support for mapping of network folders
14) Add Screen size calibration to fit video to screen
15) Add Network Host Name configuration
16) Add Japanese (S-JIS) text encoding
17) Add Korean (EUC-KR) text encoding
18) Add Thai (TIS620) text encoding
19) Add system time synchronisation with time servers
20) Add external USB DVD-ROM support**
21) Add Auto-Play function when a disc is inserted in the external USB DVD-ROM
22) Add Parental Control for disc rating
23) Fix reboot action when the power button on remote control is pressed
24) Fix lip-sync with DTS audio in 23.976fps video
25) Fix punctuation order of Hebrew text encoding
26) Fix internal subtitle in MKV to display according to default flag
27) Fix internal HDD capacity information correctly above 1TB
28) Fix Simplified/Traditional Chinese characters display under English Language Menu
29) Fix external USB DVD-ROM unable to eject once mounted
30) Fix the extra directories present when returning to Home menu from browser
31) Fix system freeze when another USB device is attached while the wireless N dongle is in use
32) Fix internal Simplified Chinese SRT subtitle present in MKV container format
33) Fix internet radio broken link
34) Improved playback of files in sequence via network
35) Remove File Copy and Setup menu from Home menu
36) Remove unicgi (Neighbour Web) application from Extension Info
-Time Sync
-Size
-Position
hi play on users...can someone give detailed point by point plus n minus on Play on hd & Xtreamer i have 2 xtreamers and looking for a media player for my Brother in law and maybe if you guys can post a few screen shots of new GUI of Playon Hd based on sdk 2 and what price you have purchased Playon and where ....Thanks in Advance :)
hi play on users...can someone give detailed point by point plus n minus on Play on hd & Xtreamer i have 2 xtreamers and looking for a media player for my Brother in law and maybe if you guys can post a few screen shots of new GUI of Playon Hd based on sdk 2 and what price you have purchased Playon and where Also would like to know like XMP does POHD display info icons on screen like ( wifi/web/hdd ip adress/nas/FTP/upnp) will it support a nas (like say if I have e-trayz ) and are two diplays supported my problem with XMP is every time I have switch between two display my plasma & PJ I have remove hdmi cable as I don't want to use my HT will component n hdmi can be used for two diffrent displays....Thanks in Advance :)
hi,
Here goes the answers for your query,
Both, the Xtreamer and A.C.Ryan units are based on RealTek chips, they have their own GUI's, Xtreamer you must know better as your an owner, and for Playon!HD's GUI, you can get them on youtube. Portability wise, Xtreamer beats PlayOn! HD. But i guess Xtreamer can only accept a 2.5" HDD internally (max 750GB I guess) while PlayOn! HD can accept a 3.5" HDD internally (max 2TB i guess). This depends upon the users choise.
While A.C.Ryan supports HDMI 1.3, Optical and Coaxial, Composite, Component and 10/100 RJ45 Network, the xtreamer is limited to HDMI 1.3,10/100 RJ45 Network, Composite and Optical. Again this depends upon the users choise. I use only HDMI 1.3 so this would not matter to me.
Both players are fitted with USB Host (2) and USB Slave (1) and will support multiple formats for the hard drive including NTFS Read and Write support.
The A.C.Ryan also comes with a card reader integrated, not sure with the Xtreamer.
Both the players can be access devices over the network, wired or wireless.
PlayOn! HD can download from Bittorrent, may be Xtreamer can also, not sure.
As far as the types of file formats (video/audio) played, there is no difference in the two players. But I'm still not clear wether the Xtreamer can decode/bitstream DD-TrueHD and DTS-HD-MA (some people say that it does based on spec, but no practical test done ........ with the latest firmware, Mr.Ashish from this forum had confirmed that it does not do the same). But PlayOn! HD supports only DTS-HD-MA with the latest firmware, but no support for DD-TrueHD.
And finally coming to the price point, PlayOn! HD is selling at 12.5K+12.5% tax (can be negotiated to 11.5K flat and if you do not require the HDMI cable another -1.5K), but Xtreamer is selling at 8.9K with free shiping I guess.
So from the price POV, if HD audio O/P and 2TB internal HDD support is not required, and can do away with a HDMI cable.......... Xtreamer is the choise. But I guess HD audio support will come sooner or later and 750GB internall HDD is sufficient and HDMI!!!! would be prefered, So the Xtreamer will definitely win. But if PlayOn! is ready to give away at Xtreamers price, then it would be a good competition.
cheers.
