dheerajin
Hi Guys,
I am looking power amplifier for my speakers which are having 4 ohm impedance and sometimes they dip much below that. Right now my integrated amp is bi-wired for them but it is suggested by manufacturer that in case of bi-wiring impedance of the associated speakers should be 8 ohm. Even then amplifier has great slam and dynamic response, but to be sure to not to have any damage to the amplifier, i am willing to incorporate power amp with high current capability. There are two options for me either go for Class-D power amp or class-AB poweramp even mono blocks. Problem is only budget, which is 80K INR. Secondly in bi-wiring mode i got good results from my integrated amp, so is there any power amp with two speaker terminals available. If power amp is hi-current amp then single terminal would do so.
My existing chain is
SBOOSTER power supply-SOTM SMS 200- HOLO Spring DAC-YAMAHA AS2000-PSB SYNCHRONY Floorstandars
Please suggest suitable power amps as per your experience.
