You mean, you got a turntable as your first item; don't have any any amplifier/speakers? I am suspecting that you meant to ask phono Preamp.HI I ahve just got the Rega 1 and need a pre amp. Which one should i get ... please help.
ok i have ProAC book shelf speakers and a Yamaha amp.You mean, you got a turntable as your first item; don't have any any amplifier/speakers? I am suspecting that you meant to ask phono Preamp.
Please share what all items you already have which will help folks here to advise.
What model of Yamaha?ok i have ProAC book shelf speakers and a Yamaha amp.
It depends and that is the reason I asked for the model number of Yamaha and if possible, picture of back panel. Usually, most of the integrates come with phono input. If you can see one in your integrated, connect your Rega to that and you should be good.its an Integrated Stereo amplifier.. i connected but no sound came ??? am a novice with connections
Should the sound have come am i connecting something wrong...
Depending on your current setup, I think, one of these should be fine.ok thankyou... any suggestion for a good preamp or any of these will do ?
