Pyle PFA400U 100-Watt Class-T Amplifier
mdharan
Hello FM's...
Any body using Pyle PFA400U 100-Watt Class-T Hi-Fi Audio Amplifier with USB SD Reader and AC Adapter. What are the Pro's and Con's ?
I ordered the same and my friend is getting it from US, I will receive it by the month end.
http://www.amazon.com/Pyle-PFA400U-100-Watt-Class-T-Amplifier/dp/B0071HZ5RI/ref=pd_sim_e_1
I want to use it with Blutooth adopter for my bed room, so i bought this also...
http://www.amazon.com/BestDealUSA-Bluetooth-Receiver-Adapter-Speaker/dp/B00ANDHBNS/ref=pd_sim_e_5
Will it work for me to play via my mobile? also i have my old Kenwood Hi Fi system Speakers.
I changed my mind from Topping TP 20 because of the USB option, Is that correct ?
Murali
Congrats!
But not to rain into your party, that says adapter with 12V,2A. Means it takes 24W input power supply. How it would deliver 100W? Seems something fishy.
Hello every one,
Received the amp, Connected to my Kenwood speakers sounds OK for me and also the Bluetooth adopter works with my phone it paired immediately and connects well.
As Omishra pointed out it doesn't sound big but with 2amps adopter its enough for my bed room.
Thank you,
Murali.
