Hi Friends,
Recently i had opportunity to try out 'how power quality affects sound quality'. The opportunity was not across all scenarios, rather it was limited to digital conversion. e.g.
DAC where digital is converted to analog signal
DDC where digital is converted to digital again
In both the above things, i observed changes in sound when power adapter / power supply was changed. Sounds surprising and hard-to-believe since this is digital.
My most varied experiment could happen bcos one of my device requires 5 volts. (normally 12 volts or 12+ are required in most devices)
After purchasing the high-end device and listening to almost one month, i was not feeling comfortable about the sound. Yes it took me one month to realize that 'something' is not correct.
Since it required 5v power, I had many options to try this out. These options b,c,d and then e did not occur to me immediately, rather they came to my mind gradually. step-by-step. I could not afford Linear Power Supply, hence following experiments were made possible:
a) power adapter which had come with the original device. The output was 5 volts.
b) power adaper of another DAC which outputs 5V. The DAC was Fiio D03k.
c) Phone chargers which normally output 5 volts. so i tried
- apple phone charger
- apple ipad charger
- samsung note5 charger
- samsung note3 charger
- samsung j7 charger
d) Then came into my mind battery power. But how to get 5volt battery. Here is what i tried first
- Apple ipad USB out - 5 volts
- samsung note5 USB out - 5 volts
- samsung note 3 USB out - 5 volts
- samsung j7 USB out - 5 volts
e) Then one more better option came to mind. Battery pack which is used to charge mobile:
- Intex battery pack - i borrowed from my friend as i do not still have one.
In the order of sequence, i found the last option was sound best to my ears.
Now WHY this happens, i will write separately in the same thread.
I know this topic might have been discussed before, but it always haunted me HOW it can happen since this is all digital....
So my limited understanding might be useful for some. Thanks for reading.
Amit.
Amit.
