Let us know what OS you are using Win7 or 8 or some other. Based on that we can suggest. If using Win7 or 8 then by default you get the file sharing option under the "Workgroup" which you can see when you open the Windows Explorer. Once you create a workgroup then go to the network settings and enable file sharing preferably with the password or within the network. This makes your files on the PC visible on the network which the Pi also would be part of and you can stream them after mapping on your Pi under Samba or some other file sharing protocol.
yeah :yahoo:. I followed the same. Now, i can stream files from computer. :yahoo:.Big thanks for detailed instructions.
Now next problem. I cant "set content" for the network files (set folder as movies, music videos...) . Can that be done, so that it can be added to library?
