pradeepkamat
Image of what to be burnt on microd sd card?
			https://www.raspberrypi.org/downloads/Image of what to be burnt on microd sd card?
Recently tried Pi3 as usb source for hi resolving music system. I was not comfortable overall. I could connect the pi3 wired connection after so many effort and help from my friend. The sound was smooth, but I could hear some occasional hiss sound. In-built Wi-Fi connection made available after a long trial effort, but the performance is very poor, signal seems to be very weak.
1. I used following with 2.4A 5 V adaptor to power the device. Is it falling short??
Raspberry Pi 3 Model B Complete Kit | eBay
2. Use rune audio. Made the router dhcp none mode, put the PC& Pi3 device static IP config. Tried for Wi-Fi adaptor to avail wireless connection, till date I could not make it work. Static IP configuration made my other device connection a bit problematics.
3. Compared rune audio (through PI3) with bug head player (through i7 PC). My observation later is clear winner with details, depth and sound stage. Pi3 sound was smooth but lacks details, depth and sound stage comparatively.
Like to know more and want advice from experienced Pi user, if I am missing something to work out. I was expecting something different, after reading many reviews on PI user. A single component device will work as one of the best usb source for HIFI music. ..!!!!!
Read my post couple if pages old. I found the sound through the USB horrible. Too much noise and static sound coming through. I then got a digi+ hat board, connected the digital out to a dac and the sound is fantastic. Many forums have complained of static sound coming from the USB.Recently tried Pi3 as usb source for hi resolving music system. I was not comfortable overall. I could connect the pi3 wired connection after so many effort and help from my friend. The sound was smooth, but I could hear some occasional hiss sound. In-built Wi-Fi connection made available after a long trial effort, but the performance is very poor, signal seems to be very weak.
1.I used following with 2.4A 5 V adaptor to power the device. Is it falling short??
2.Use rune audio. Made the router dhcp none mode, put the PC& Pi3 device static IP config. Tried for Wi-Fi adaptor to avail wireless connection, till date I could not make it work. Static IP configuration made my other device connection a bit problematics.
3.Compared rune audio (through PI3) with bug head player (through i7 PC). My observation later is clear winner with details, depth and sound stage. Pi3 sound was smooth but lacks details, depth and sound stage comparatively.
Connecting the hdmi to their avr or pre amp should also suffice.Read my post couple if pages old. I found the sound through the USB horrible. Too much noise and static sound coming through. I then got a digi+ hat board, connected the digital out to a dac and the sound is fantastic. Many forums have complained of static sound coming from the USB.
MaSh
Sent from my Redmi Note 3
Yes hdmi is fine, but that can go either to TV or receiver only. I wanted to bypass the receiver totally for music listening. HDMI is used for Movies.Connecting the hdmi to their avr or pre amp should also suffice.
Sent from my ONE A2003 using Tapatalk
4 ways to improve rpi audio:Recently tried Pi3 as usb source for hi resolving music system. I was not comfortable overall. I could connect the pi3 wired connection after so many effort and help from my friend. The sound was smooth, but I could hear some occasional hiss sound. In-built Wi-Fi connection made available after a long trial effort, but the performance is very poor, signal seems to be very weak.
1. Get a linear power supply for rpi
2. Get Hifiberry digi+ (trafo version preferred)
3. Use Moode
4. Forget USB audio
I think PCs don't have that type of connectivity for putting these types of I2S to SPDI/F converters.1,2,3 ok but MY DAC works best in USB mode!
Will it exceed the PC SQ ?
Well I have been using Pi for music for about six months now. I throw music wirelessly from Pi using Moode and Minimserver, to the AVR. The music sounds very good but its a life full of glitches. The Cambridge Connect app reads both the servers but is unable to play the song. Other Upnp or DLNA apps are not doing any better. Anyway, for iOS, there aren't many good interfaces. My conclusion now is to stop all these hassels and go for something that'll make life easier. Every time, its taken me more than 20 minutes just to set up music and now even that does not happen, the apps just can't play the music on external HDD. Might be time to move on.
I use MinimServer, and that's the only thing I would recommend for the Raspberry Pi. You can also install it on Synology.
No need to install it on Synology, Synology has its own UPnP Media Server which is much much better than minim
^^ R U using UPnP/Airplay to through music or you using Moode itself to read the music from connected HDD and play music..????
